Harold Posted March 14, 2022 Posted March 14, 2022 I have the XRS4500 and last night it was working fine no problems. I get up this morning and the light on the front is blinking red and blue, I ahven t a clue as to why its doing or why. Please help. What could be causing this? I need help quick. thank you so much!! Quote
Ryu Posted March 14, 2022 Posted March 14, 2022 (edited) do you see anything similar to this? not sure if this applies to 4500 as well Edited March 14, 2022 by Ryu 1 Quote
Harold Posted March 14, 2022 Author Posted March 14, 2022 Yes!! Left it unplugged for a few seconds, 30 at least and still nothing Quote
Harold Posted March 14, 2022 Author Posted March 14, 2022 @Ryu yes the bottom one. Its blinking red and blue Quote
Ryu Posted March 14, 2022 Posted March 14, 2022 just change power options from setting or buzz utilities Quote
Harold Posted March 14, 2022 Author Posted March 14, 2022 @RyuI cant even access the main menu at all. It just shows a blue screen that says no signal Quote
Ryu Posted March 14, 2022 Posted March 14, 2022 then follow suggestion posted by nbs at post number 3. 1 Quote
Harold Posted March 14, 2022 Author Posted March 14, 2022 @dishuser where the hole for it? I cant find it Quote
dishuser Posted March 14, 2022 Posted March 14, 2022 on the back insert a toothpick in the av hole Quote
nbs. Posted March 14, 2022 Posted March 14, 2022 (edited) 4 minutes ago, Ryu said: follow the guide it explains everything in detail Edited March 14, 2022 by nbs. 1 Quote
Harold Posted March 14, 2022 Author Posted March 14, 2022 @dishuser using a paper clip. LOL I cant feel button in there at all. I apologize for drawing a brain bubble Quote
dishuser Posted March 14, 2022 Posted March 14, 2022 Just now, Harold said: @dishuser using a paper clip. LOL I cant feel button in there at all. I apologize for drawing a brain bubble it might be too thin I use a toothpick Quote
nbs. Posted March 14, 2022 Posted March 14, 2022 the button is near the top of av hole You should be able to feel it being pushed in Quote
Harold Posted March 14, 2022 Author Posted March 14, 2022 @nbs.nothing. Ive unplugged it, pressed the reset button. Nothing. My remote wont even trigger the box Quote
dishuser Posted March 14, 2022 Posted March 14, 2022 1 minute ago, Harold said: @nbs.nothing. Ive unplugged it, pressed the reset button. Nothing. My remote wont even trigger the box hold the button down and plug power adapter in 1 Quote
nbs. Posted March 14, 2022 Posted March 14, 2022 are you holding the button down with toothpick and then plugging in the buzz? Quote
Harold Posted March 14, 2022 Author Posted March 14, 2022 Nope but will try that @nbs.nothing. Ive unplugged it, pressed the reset button. Nothing. My remote wont even trigger the box Quote
nbs. Posted March 14, 2022 Posted March 14, 2022 you dont press it ,you hold button down and wait for screen It can take 6 7 seconds Quote
Harold Posted March 14, 2022 Author Posted March 14, 2022 I dont know what wrong with it. I have unplugged the power and hdmi and and inserted everything like the video says and nothing. Im stumped. Quote
