Woody Posted September 24, 2023 Share Posted September 24, 2023 Anyone have issue where guide loads tgen when u oower off box tgen turn it back it loses guide listings at all Quote Link to comment Share on other sites More sharing options...
dishuser Posted September 24, 2023 Share Posted September 24, 2023 model? firmware version? software version? server connection method? 2 Quote Link to comment Share on other sites More sharing options...
Woody Posted September 24, 2023 Author Share Posted September 24, 2023 4900 current 893 version and mac server Quote Link to comment Share on other sites More sharing options...
dishuser Posted September 24, 2023 Share Posted September 24, 2023 shutdown or suspend? Quote Link to comment Share on other sites More sharing options...
Woody Posted September 24, 2023 Author Share Posted September 24, 2023 Shut down and just came home turned on box and lost all my fav channels so i reset box and did restore not sure wat happened Quote Link to comment Share on other sites More sharing options...
Woody Posted September 24, 2023 Author Share Posted September 24, 2023 Just seems that since new update came out box has been acting up so i fihure fresh install might correct issues Quote Link to comment Share on other sites More sharing options...
dishuser Posted September 24, 2023 Share Posted September 24, 2023 mine has been fine since I took update almost 3 weeks ago Quote Link to comment Share on other sites More sharing options...
Woody Posted September 24, 2023 Author Share Posted September 24, 2023 Yea not sure maybe someybibg didnt take right will see wat hapoens now Quote Link to comment Share on other sites More sharing options...
Emporium Posted September 24, 2023 Share Posted September 24, 2023 My 4900 has been even better since the update. My primary server is XC login based, and before the update, if I scrolled through the EPG, it would eventually slow down like crazy and then crash (repeatable on both my 4900 units). Now, not only does do they not slow down and crash, but seems pretty instantaneous at loading the EPG. And love the multiple favorites groups now. One for me, and one for the Mrs. 2 Quote Link to comment Share on other sites More sharing options...
Woody Posted September 24, 2023 Author Share Posted September 24, 2023 Now guide is stuck all it says is loadimg and nothing is loafing up.. would that be server issue been saying losfing for over an hour Quote Link to comment Share on other sites More sharing options...
Emporium Posted September 24, 2023 Share Posted September 24, 2023 Quite possible. Is there any way to check with your service provider (or a friend who uses the same service) ? If it works fine for others, then I'd say to send a PM to allaboutbuzz, and give him the details about the service and maybe he can look into it. Maybe there is something different/customized that they do on their panel/portal. 1 Quote Link to comment Share on other sites More sharing options...
Savageturt Posted September 24, 2023 Share Posted September 24, 2023 I can’t evn get my box to work. I have the xr4500. But I dnt have any servers. And all the servers I find are not working Quote Link to comment Share on other sites More sharing options...
dishuser Posted September 24, 2023 Share Posted September 24, 2023 8 minutes ago, Savageturt said: I can’t evn get my box to work. I have the xr4500. But I dnt have any servers. And all the servers I find are not working that's why it doesn't work 1 Quote Link to comment Share on other sites More sharing options...
Emporium Posted September 24, 2023 Share Posted September 24, 2023 29 minutes ago, Savageturt said: I can’t evn get my box to work. I have the xr4500. But I dnt have any servers. And all the servers I find are not working First of all, don't hijack other threads, especially since your issue is unrelated. Secondly, if you were hoping to use the box with "free" servers you find posted today and gone before you even try them, you will be very disappointed. Find a service, and buy a subscription. Subs are pretty cheap, and some even offer short trials so you can try (to ensure you like the channel lineup they offer). And this is the wrong forum if you are looking for services, since we only support BuzzTV hardware/software in this forum. 4 Quote Link to comment Share on other sites More sharing options...
Woody Posted September 25, 2023 Author Share Posted September 25, 2023 Def guide is server issue as for my otger issue seem that a fresh install had corrected everything 2 Quote Link to comment Share on other sites More sharing options...
Woody Posted October 3, 2023 Author Share Posted October 3, 2023 Ok so guide qent out on me again after i shut down and turbed box back on its noy a server issue froend has same service on a diff type android box and his guide has not gone out... seems that when you shut down then turn box back on later it loses all stored guide info... Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 3, 2023 Share Posted October 3, 2023 don't use suspend in powerkey definition Quote Link to comment Share on other sites More sharing options...
Woody Posted October 3, 2023 Author Share Posted October 3, 2023 No it happens when i shut down and susprnd function blue light stays on Quote Link to comment Share on other sites More sharing options...
Emporium Posted October 3, 2023 Share Posted October 3, 2023 16 hours ago, Woody said: No it happens when i shut down and susprnd function blue light stays on Suspend function, blue light does NOT stay on. It goes red. If you power up and you don't see the animated Buzz logo, then you were on suspend. If you see the Buzz Animated logo, then you were shutdown. 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 3, 2023 Share Posted October 3, 2023 I set mine to suspend and blue light stays on version 5.0.905 was the same with version 5.0.901 Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted October 4, 2023 Share Posted October 4, 2023 41 minutes ago, dishuser said: I set mine to suspend and blue light stays on version 5.0.905 was the same with version 5.0.901 Which model #? Quote Link to comment Share on other sites More sharing options...
nbs. Posted October 4, 2023 Share Posted October 4, 2023 Both my x5 and 4900 go red on suspend 1 Quote Link to comment Share on other sites More sharing options...
Ryu Posted October 4, 2023 Share Posted October 4, 2023 mine go red as well Quote Link to comment Share on other sites More sharing options...
Emporium Posted October 4, 2023 Share Posted October 4, 2023 I just checked my X5, B5 and E5 and all go RED when suspend. X5 is on .905, B5 on .893, and E5 on .799 still. But I don't think BuzzTV 5 has anything to do with the LED colors on modes, that would "probably" be controlled in the firmware. B5 is normally Blue when powered on, and Green light to show my ethernet cable is connected. Go into suspend and Green light goes off, and Blue turns Red. Actually on the B5, if I power up the box, then put it in suspend, and then power up, and then quickly try to put it in suspend as soon as the blue light come on but before video is displayed, and repeat that 4 or 5 times, the unit eventually hangs OK, not fair, very abnormal use of the box. But I tried the same on the X5 (and E5) and could not reproduce it. Maybe some sort of race condition on the B5 due to slower CPU, as it is still initializing as it comes out of suspend mode. Only reason I even did that, was because I was trying to see if the RED/BLUE lights on the B5 were actually a single dual color LED or just 2 small LED one on top of the other very close. And therefore I was close up on the box and not looking at the screen as I was putting it to suspend and on, suspend and on, etc. Just curious, is the E5 going to get updated soon ? Public release is still on .799 for E5. Quote Link to comment Share on other sites More sharing options...
Woody Posted October 4, 2023 Author Share Posted October 4, 2023 4900 5.0.893 wpuld like to grt beta updates if possible but i put on susoend and it stays blue and just turned box on again and guide was missing again all saying loading guide was full when i shut iy off Quote Link to comment Share on other sites More sharing options...
