Betatester Posted July 21, 2022 Posted July 21, 2022 CoreELEC installation instructions for use with BuzzTV X5 (4G/1Gbit). Cheers, Team CoreELEC 1 Quote
Emporium Posted July 22, 2022 Posted July 22, 2022 I'm assuming it will just run off the MicroSD, and ignore the onboard eMMC ? Just curious on WHY you would consider doing this on a new box, with so much going for it ? If you want Kodi, just install Kodi as an app. CoreElec is great on older devices if they are out of support or have no dedicated IPTV app like BuzzTV5, but I just don't see the point on using it on a Buzz box, and the latest flagship one at that. 2 Quote
Ryu Posted July 22, 2022 Posted July 22, 2022 (edited) I 100% agree with you @Emporium. there site says but im not risking it "Installation to eMMC is currently unsupported" Edited July 22, 2022 by Ryu Quote
allaboutbuzz Posted July 22, 2022 Posted July 22, 2022 21 hours ago, Betatester said: CoreELEC installation instructions for use with BuzzTV X5 (4G/1Gbit). Cheers, Team CoreELEC This is a collaboration between BuzzTV and CoreElec We will make a Full Announcement about it in the coming weeks, and it will be available for more models as well. 2 Quote
allaboutbuzz Posted July 22, 2022 Posted July 22, 2022 16 hours ago, Emporium said: I'm assuming it will just run off the MicroSD, and ignore the onboard eMMC ? Just curious on WHY you would consider doing this on a new box, with so much going for it ? If you want Kodi, just install Kodi as an app. CoreElec is great on older devices if they are out of support or have no dedicated IPTV app like BuzzTV5, but I just don't see the point on using it on a Buzz box, and the latest flagship one at that. 2 Big Differences on CoreElec - Uses Linux Video Drivers and Codecs, which work much better than Android for Video and Audio Playback. - Auto Frame Rate Feature. 3 Quote
Betatester Posted July 22, 2022 Author Posted July 22, 2022 2 hours ago, allaboutbuzz said: This is a collaboration between BuzzTV and CoreElec To confirm: The announcement is provided as a courtesy. This edition of CoreELEC was developed in collaboration with BuzzTV, and can only run from external media, which should make it impossible to render the device unusable. Sometime in the future, after more testing, this might change. We are currently encouraging people to test and report issues back to us by submitting a system log via our user forums. Thank you, Team CoreELEC 1 Quote
Betatester Posted July 28, 2022 Author Posted July 28, 2022 (edited) CoreELEC 19.5-Matrix RC2 is now available. Changes Since 19.5-Matrix RC1: Added SC2, S905X4 support Added support of AV1 hardware decoder for SoC SC2 or newer Added Wifi driver Unisoc UWE5621 Added support of PHY RTL8211F-VD Added support for Ugoos AM7 and X4 Added support for BuzzTV X5 Reworked auto colour subsampling and colour depth detection Fixed no sound on GXL devices The download link is here Installation instructions can be found here Be aware this version can only boot from external media. Cheers, Team CoreELEC Edited July 28, 2022 by Betatester Quote
sunnyc Posted July 29, 2022 Posted July 29, 2022 I tried the 19.5 RC2, burned it to a USB flash drive. Followed the toothpick reset method, nothing boots up. Has any one had any luck , can you share your experience. Quote
dishuser Posted July 29, 2022 Posted July 29, 2022 22 minutes ago, sunnyc said: I tried the 19.5 RC2, burned it to a USB flash drive. Followed the toothpick reset method, nothing boots up. Has any one had any luck , can you share your experience. you got to recovery screen? you renamed the file? Quote
sunnyc Posted July 29, 2022 Posted July 29, 2022 3 minutes ago, dishuser said: you got to recovery screen? you renamed the file? No, I did not see recovery screen. It came up with SORO logo and constantly going thru recycle. I am waiting to see if it is going to boot after few attempts. Yes, I renamed the file as mentioned in the instruction and copied it to the root folder. Quote
sunnyc Posted July 29, 2022 Posted July 29, 2022 12 minutes ago, sunnyc said: No, I did not see recovery screen. It came up with SORO logo and constantly going thru recycle. I am waiting to see if it is going to boot after few attempts. Yes, I renamed the file as mentioned in the instruction and copied it to the root folder. After several reboots Corelec application screen came up. The issue now is, remote keys don't work. I cannot select the "next" button. Quote
sjh Posted July 29, 2022 Posted July 29, 2022 just purchased buzz x5 box installed latest update now it shows it has being a SARO gt5000 or something also has several issues with some apps please advise Quote
dishuser Posted July 29, 2022 Posted July 29, 2022 4 hours ago, sjh said: just purchased buzz x5 box installed latest update now it shows it has being a SARO gt5000 or something also has several issues with some apps please advise you're in the wrong thread Quote
sunnyc Posted July 29, 2022 Posted July 29, 2022 11 hours ago, dishuser said: what about mouse button? tried that, no luck. 1 Quote
allaboutbuzz Posted July 29, 2022 Posted July 29, 2022 On 7/27/2022 at 9:31 PM, Betatester said: CoreELEC 19.5-Matrix RC2 is now available. Changes Since 19.5-Matrix RC1: Added SC2, S905X4 support Added support of AV1 hardware decoder for SoC SC2 or newer Added Wifi driver Unisoc UWE5621 Added support of PHY RTL8211F-VD Added support for Ugoos AM7 and X4 Added support for BuzzTV X5 Reworked auto colour subsampling and colour depth detection Fixed no sound on GXL devices The download link is here Installation instructions can be found here Be aware this version can only boot from external media. Cheers, Team CoreELEC Seems the IR Codes were not included with this build for our boxes after speaking to the Dev team on our side They will reach out to your side to resolve this Thanks 2 Quote
Betatester Posted December 6, 2022 Author Posted December 6, 2022 Sorry for the late reply. I had to deal with a personal issue. For those who have issues with the RC2, please use the latest nightly instead. Quote
Ryu Posted March 8, 2023 Posted March 8, 2023 (edited) just to keep this update. currently supported devices Amlogic-ng Amlogic-ne BuzzTV X5 64 AI / 128 AI BuzzTV X5 64 AI / 128 AI BuzzTV HD5 BuzzTV HD5 BuzzTV U5 BuzzTV U5 Installation Device Edition DTB SoC BuzzTV X5 64 AI / 128 AI 4G sc2_s905x4_buzztv_x5 S905X4 BuzzTV HD5 4G s4_s905y4_buzztv_hd5.dtb S905Y4 BuzzTV U5 4G sc2_s905x4_buzztv_u5_4g_1gbit S905X4 Edited March 8, 2023 by Ryu 1 Quote
