gig63 Posted August 26, 2023 Posted August 26, 2023 With the new update have had slow channel changing, I've done all the normal things cache, background apps, reboot, unplug internet, nothing has changed. I did find in live tv menu/settings/configuration go all the way to the bottom to stream format, it was on automatic after the update so i put it back to TS where it was before no difference update made no difference, I put it back to auto now Everything is set to the way it was before update Thank you for your time everyone Quote
nbs. Posted August 26, 2023 Posted August 26, 2023 There is an update going out on Monday (pretty sure) that fixed an issue with one server Not sure it's the one you're using 1 Quote
dishuser Posted August 26, 2023 Posted August 26, 2023 where are you grabbing epg from? server or xml? Quote
gig63 Posted August 27, 2023 Author Posted August 27, 2023 It is grabbing epg from xml would that make difference in channel change speed Thank you for your time Quote
gig63 Posted August 27, 2023 Author Posted August 27, 2023 I made those changes and put it back to TS seams faster see what happens Thank you so much for your time Quote
dishuser Posted August 27, 2023 Posted August 27, 2023 On 8/27/2023 at 12:37 AM, gig63 said: I made those changes and put it back to TS seams faster see what happens Thank you so much for your time Expand I use auto and it selects hls which is better for catchup channels my neighbour picks ts like you but doesn't use catchup Quote
gig63 Posted August 27, 2023 Author Posted August 27, 2023 Okay maybe I'll put it back to auto see what happens Thanks Quote
gig63 Posted August 27, 2023 Author Posted August 27, 2023 Okay so with the changes that you suggested dishuser I took and reset my internet and cleared cashe, closed background apps and restarted, everything back to normal Thank you so much for your time 1 Quote
gig63 Posted August 30, 2023 Author Posted August 30, 2023 Time to update first a little info: I have a X5 running provider on xc api, the box plugged into my Marantz SR5003 witch is plugged into my Samsung old plasma tv no cec turned on. I still have all the changes the same as when i posted last but one. I had to switch from Primary player to backup because my sound was out of wack with the video witch i have always had to use with any of the buzz box's, and now that i am on backup I have slow channel changes again. Just a heads up Thank you everyone for your time Quote
Emporium Posted August 30, 2023 Posted August 30, 2023 backup player has always been slower than Primary player for channel changes. BTW: Since you are using XC API, with Primary player, had you tried switching stream type from TS or Automatic to manually selecting M3U8/HLS ? Quote
gig63 Posted August 30, 2023 Author Posted August 30, 2023 The fastest changes i get is using TS, which is close will leave for now may want to try real time streaming come football time Quote
dishuser Posted August 30, 2023 Posted August 30, 2023 On 8/30/2023 at 1:45 AM, gig63 said: The fastest changes i get is using TS, which is close will leave for now may want to try real time streaming come football time Expand I use auto and channel changes are instant on same service by the way auto selects hls Quote
allaboutbuzz Posted August 30, 2023 Posted August 30, 2023 On 8/30/2023 at 12:35 AM, gig63 said: Time to update first a little info: I have a X5 running provider on xc api, the box plugged into my Marantz SR5003 witch is plugged into my Samsung old plasma tv no cec turned on. I still have all the changes the same as when i posted last but one. I had to switch from Primary player to backup because my sound was out of wack with the video witch i have always had to use with any of the buzz box's, and now that i am on backup I have slow channel changes again. Just a heads up Thank you everyone for your time Expand Backup Player is VLC. Its libvlc as this version doesn't require the GUI and is open source, its main use is for Movies and TV shows. Not Live TV That's why channel changing is slower. 3 Quote
MY2SONS Posted September 30, 2023 Posted September 30, 2023 I don't think this is the spot, but cound not find what i am looking for, trying to find if there is a setting for recently viewed channels for more than just hitting the back button on remote, is there a setting for maybe to view like the last 5 channels you viewed. TY in advance Quote
Ryu Posted September 30, 2023 Posted September 30, 2023 (edited) on bt400 hold down last button (button underneath home button) or if different remote then hold down back/last button for few second. Edited September 30, 2023 by Ryu 1 Quote
MY2SONS Posted September 30, 2023 Posted September 30, 2023 I'll try that when i get back hme tonight 1 Quote
dishuser Posted September 30, 2023 Posted September 30, 2023 On 9/30/2023 at 7:38 PM, MY2SONS said: I'll try that when i get back hme tonight Expand it's the same for every remote long press brings up last channel history 4 Quote
