jbana48 Posted December 24, 2022 Share Posted December 24, 2022 Factory reset & Updated from Buzz XRS 4500 Firmware V20211108 to BuzzTV5 firmware 5.0.793 version v20220919 I can't record VOD & TV Series to internal box memory or USB drive but I can record Live TV. Any suggestions to be able to record? Quote Link to comment Share on other sites More sharing options...
dishuser Posted December 24, 2022 Share Posted December 24, 2022 you were already told in other thread to download you were also told the same at another site 1 Quote Link to comment Share on other sites More sharing options...
Emporium Posted December 24, 2022 Share Posted December 24, 2022 You do need to make sure that you select the proper location for the "download storage". From LiveTV, Menu->PVR->PVR Options And the last option should be "Download storage". Select it, and make sure it is pointing to your storage location. By default it is NOT set. Then from PVR or TV Series, you should have an option on the far right when you select a title, to "download". Simple. Quote Link to comment Share on other sites More sharing options...
dishuser Posted December 25, 2022 Share Posted December 25, 2022 21 minutes ago, Emporium said: You do need to make sure that you select the proper location for the "download storage". From LiveTV, Menu->PVR->PVR Options And the last option should be "Download storage". Select it, and make sure it is pointing to your storage location. By default it is NOT set. Then from PVR or TV Series, you should have an option on the far right when you select a title, to "download". Simple. VOD Quote Link to comment Share on other sites More sharing options...
dishuser Posted December 25, 2022 Share Posted December 25, 2022 by the way? how many threads on same topic do you plan on starting here? just curious cause if I need to set to ignore before you annoy me...lol Quote Link to comment Share on other sites More sharing options...
nbs. Posted December 25, 2022 Share Posted December 25, 2022 Same thing on two other sites 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted December 25, 2022 Share Posted December 25, 2022 14 minutes ago, nbs. said: Same thing on two other sites yes I know that's why I asked...lol they know how to start threads but don't know how to follow advice Quote Link to comment Share on other sites More sharing options...
Emporium Posted December 25, 2022 Share Posted December 25, 2022 5 hours ago, dishuser said: VOD Yes, that is for VOD.. the Recording location for actual LiveTV PVR is the first setting in that menu which is the recording location. I know it seems strange, but in the PVR options menu, you have the recording location option on the top, and the download location for downloads, at the bottom. I do believe the recording location is set to some default. But the download location I believe is blank if it is not manually set. Quote Link to comment Share on other sites More sharing options...
dishuser Posted December 25, 2022 Share Posted December 25, 2022 1 hour ago, Emporium said: Yes, that is for VOD.. the Recording location for actual LiveTV PVR is the first setting in that menu which is the recording location. I know it seems strange, but in the PVR options menu, you have the recording location option on the top, and the download location for downloads, at the bottom. I do believe the recording location is set to some default. But the download location I believe is blank if it is not manually set. read first post Quote Link to comment Share on other sites More sharing options...
