Upgrade and remote issues ?
Scuba1900
I have the same issue with my XRS4900. I’ve paired the remote and it works when the box is on. But if I power off the box (using the remote) I can’t turn it back on. The only way to turn it on is to unplug the box, and plug it back in. Then it boots up and the remote will still work for everything else. But if I turn it off, I have to repeat the same unplugging replugging cycle. I never had this issue before the update.
you're in the wrong thread
