ppat86 Posted October 16, 2022 Share Posted October 16, 2022 I have a brand new BuzzTV X5 64 AI which is connected via Wi-Fi. The box works fine until I switch off the TV and not watch any programs for a few hours (e.g., overnight). The box loses internet connection with the Connection setting displaying a "No Internet" message for my wi-fi network. Toggling the Wi-Fi option or forgetting the wi-fi network and reconfiguring the same wi-fi network does not help. The box connects successfully to the wi-fi but continues to show "No Internet". All the other devices in the house including laptops and two other non-BuzzTV IPTV boxes have no issues with the wi-fi. The only workaround is to physically unplug and re-plug the power cable on the box after which it takes a long time to initialize and download the IPTV channels. This is not a sustainable option. Any suggestions? 1 Quote Link to comment Share on other sites More sharing options...
Ryu Posted October 16, 2022 Share Posted October 16, 2022 im assuming you have latest update? you said you reconfigured same network meaning your forget network and reconnect? are you on 2.4 or 5G or you have both in one network? try to split and connect on 5G first then 2.4 to see if that helps. try different router if you have avaible or swap to different if it belongs to your ISP. if nothing works then I would say try factory reset option and see if that helps Quote Link to comment Share on other sites More sharing options...
ppat86 Posted October 17, 2022 Author Share Posted October 17, 2022 I do have the latest update and yes, I did a "forget network and reconnect". I have 2.4 and 5 G wi-fi networks separated and have tried switching from one network to another. The box connects to both wi-fi networks successfully when I switch but once a network goes to the "No Internet" status for one, the other network has the same issue until I remove and reconnect the power cable. Another thing, there does not seem to be any specific pattern on the duration of the non-activity before the internet connection is lost. On a few occasions, the internet connection remains intact even after a gap of 10-12 hours but most times, that is not the case. I will try the factory reset option the next time the internet's status is lost/connection is not recognized. Thanks. Quote Link to comment Share on other sites More sharing options...
rkpouin Posted October 17, 2022 Share Posted October 17, 2022 I have the same problem. After somes hours, i have to reboot the device to have internet again. Quote Link to comment Share on other sites More sharing options...
Ryu Posted October 17, 2022 Share Posted October 17, 2022 21 minutes ago, rkpouin said: I have the same problem. After somes hours, i have to reboot the device to have internet again. what you have done to troubleshoot? Quote Link to comment Share on other sites More sharing options...
rkpouin Posted October 17, 2022 Share Posted October 17, 2022 I need to restart wifi on the x5 and ot works ok after that. i don’t have this ttouble on other devices (shields) thanks Quote Link to comment Share on other sites More sharing options...
ppat86 Posted October 18, 2022 Author Share Posted October 18, 2022 Rather than do a factory reset, I changed the remote power (BT-400) setting to power off instead of suspend for the box when powering off the TV. I am not sure if it is coincidence but since then, I have not lost the internet connection (one whole day). I will monitor for some more time to confirm if the problem has been resolved. 1 Quote Link to comment Share on other sites More sharing options...
ppat86 Posted October 22, 2022 Author Share Posted October 22, 2022 It's been 3+ days and no issues with the internet connection being broken. So it appears that my issue is resolved after my last configuration change. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
ppat86 Posted November 20, 2022 Author Share Posted November 20, 2022 The "no internet" issue has unfortunately resurfaced. For three weeks, my x5 had no issues with the internet but over the last week, the box loses internet connection, sometimes multiple times a day, and can't connect until it is rebooted. Any suggestions would be welcome. Quote Link to comment Share on other sites More sharing options...
Ryu Posted November 20, 2022 Share Posted November 20, 2022 13 minutes ago, ppat86 said: The "no internet" issue has unfortunately resurfaced. For three weeks, my x5 had no issues with the internet but over the last week, the box loses internet connection, sometimes multiple times a day, and can't connect until it is rebooted. Any suggestions would be welcome. I would say if its ISP device then try to swap router or if its combo unit try to swap if possible and see if that helps. if your own then try to buy a different router and see if that helps. Quote Link to comment Share on other sites More sharing options...
ppat86 Posted November 20, 2022 Author Share Posted November 20, 2022 (edited) It is not the router as all other devices using wi-fi including two other non-x5 IPTV boxes have no such problem. Edited November 20, 2022 by ppat86 Quote Link to comment Share on other sites More sharing options...
Emporium Posted November 20, 2022 Share Posted November 20, 2022 Are you using suspend, or shutdown as powerkey definition. I know it is quicker when using suspend, but issues compound over time if you use suspend. Try using shutdown instead and see if it persists. Quote Link to comment Share on other sites More sharing options...
ppat86 Posted November 20, 2022 Author Share Posted November 20, 2022 I am using Shutdown. It was that switch from Suspend that seemed to have fixed the problem for me last month until last week when the problem resurfaced. Quote Link to comment Share on other sites More sharing options...
Emporium Posted November 20, 2022 Share Posted November 20, 2022 Have you tried power cycling your router (not reset - just unplug power and plug it in again) ? I know you said other devices have no issue, but sometimes there are chipset incompatibilities so just trying to see if it may not like the WIFI chipset used in your router. You are not by any chance too close to the router (yes that is a thing) ? Quote Link to comment Share on other sites More sharing options...
Ryu Posted November 20, 2022 Share Posted November 20, 2022 59 minutes ago, ppat86 said: I am using Shutdown. It was that switch from Suspend that seemed to have fixed the problem for me last month until last week when the problem resurfaced. go to settings, network & internet, click HotSpot, Portable HotSpot Enabled turn ON, go back to wifi, turn wifi ON and it should connect to your network now. let us know please if that worked. Quote Link to comment Share on other sites More sharing options...
Ryu Posted November 20, 2022 Share Posted November 20, 2022 you can also turn hot spot button on then off. it should connect to your wifi after that. Quote Link to comment Share on other sites More sharing options...
ppat86 Posted November 21, 2022 Author Share Posted November 21, 2022 Is the Hot Spot button the white button between the Menu and Guide Buttons on the BT-400 remote? Quote Link to comment Share on other sites More sharing options...
Ryu Posted November 21, 2022 Share Posted November 21, 2022 26 minutes ago, ppat86 said: Is the Hot Spot button the white button between the Menu and Guide Buttons on the BT-400 remote? no, not on remote. go to settings on your box, it should be below your wifi networks 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted November 21, 2022 Share Posted November 21, 2022 39 minutes ago, ppat86 said: Is the Hot Spot button the white button between the Menu and Guide Buttons on the BT-400 remote? that's the live tv button 1 Quote Link to comment Share on other sites More sharing options...
ppat86 Posted November 21, 2022 Author Share Posted November 21, 2022 The box displayed the "No internet" message again today, The Hotspot trick did work though and the box reconnected to the internet needing me to unplug and then reconnect the power cable to the box. @Ryu: Thanks for your suggestion. I am hopeful though that there will be a permanent solution for this problem in a future upgrade since it is apparently not unique to my box. 1 Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted November 22, 2022 Share Posted November 22, 2022 I am not counting on an update to fix it. Heck this V5 has been a train wreck right from the get-go. I can say that for my x5 right from the beginning as well when my box order was filled on 20220624. Oh, wait that's the bad version, but anyway same date. I also must be going blind; I know while I was out driving, I saw a message not so positive about BuzzTV. However, now it is gone. Poof. Guess the censor button got it. It's a shame we can't have a box to watch simple TV on. After all this X5 was hyped big time as the best box to get. Some said Nivida killer. Heck my Firestick is playing just fine and the x5 won't. Now censorship of our comments about the product. We can have some of the team degrading folks, suggest they move on, that is allowed by allaboutbuzz. There is a guy here who requested his sd card with the files on it way before me. He still has not gotten it. Guess that's none of my business, but it does reflect on the company. So, my issue is X5 freezes, and I miss part of the program. It also will not reconnect to Wi-Fi when turning on in the morning. Thanks 2 1 Quote Link to comment Share on other sites More sharing options...
Ryu Posted November 22, 2022 Share Posted November 22, 2022 1 hour ago, Flyinghigh said: I am not counting on an update to fix it. Heck this V5 has been a train wreck right from the get-go. I can say that for my x5 right from the beginning as well when my box order was filled on 20220624. Oh, wait that's the bad version, but anyway same date. I also must be going blind; I know while I was out driving, I saw a message not so positive about BuzzTV. However, now it is gone. Poof. Guess the censor button got it. It's a shame we can't have a box to watch simple TV on. After all this X5 was hyped big time as the best box to get. Some said Nivida killer. Heck my Firestick is playing just fine and the x5 won't. Now censorship of our comments about the product. We can have some of the team degrading folks, suggest they move on, that is allowed by allaboutbuzz. There is a guy here who requested his sd card with the files on it way before me. He still has not gotten it. Guess that's none of my business, but it does reflect on the company. So, my issue is X5 freezes, and I miss part of the program. It also will not reconnect to Wi-Fi when turning on in the morning. Thanks go to settings, network & internet, click HotSpot, Portable HotSpot Enabled turn ON then turn off. now it should connect to internet. Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted November 22, 2022 Share Posted November 22, 2022 Okay, I have made that change. Maybe it will not lose connection now. Now how to I make it stop freezing? Note: I have offered Mike a team viewer connection to set my box up correctly. He told me that guy was out of town til next week. Maybe he will do the connection. Quote Link to comment Share on other sites More sharing options...
stan767 Posted December 15, 2022 Share Posted December 15, 2022 I have a xrs4500 box running build v 20221115 and IPTV ver 5.0.790 with the same problem of losing my wifi internet connection after a suspend. Turn wifi on/ and off shows no wifi at all. I don't have any hotspot option mentioned above. Only solution is to reboot the box. Quote Link to comment Share on other sites More sharing options...
dishuser Posted December 15, 2022 Share Posted December 15, 2022 3 minutes ago, stan767 said: I have a xrs4500 box running build v 20221115 and IPTV ver 5.0.790 with the same problem of losing my wifi internet connection after a suspend. Turn wifi on/ and off shows no wifi at all. I don't have any hotspot option mentioned above. Only solution is to reboot the box. then update it and see if that helps Quote Link to comment Share on other sites More sharing options...
