Chuck13 Posted September 10, 2022 Share Posted September 10, 2022 I have xrs4500 and the remote stopped working. Tried batteries etc then used it on another xrs4500 that I have and it does work. It seems like the box is not receiving the remote. I powere off/on multiple times and nothing then I tried to reset the box. I got to reset screen but unable to use remote to select options. I have multiple remotes so it is definitely the box. Any suggestions. I think I need to send it back, only about 1 year old. Quote Link to comment Share on other sites More sharing options...
nbs. Posted September 10, 2022 Share Posted September 10, 2022 (edited) You should contact them asap as the warranty is for one year If its over I would find out where the ir sensor is. Should not be too difficult to fix Edited September 10, 2022 by nbs. Quote Link to comment Share on other sites More sharing options...
Ryu Posted September 10, 2022 Share Posted September 10, 2022 use pc keyboard and mouse to factory reset from recovery screen. once done then see if remote started to work. 1 Quote Link to comment Share on other sites More sharing options...
Ryu Posted September 10, 2022 Share Posted September 10, 2022 after reset if remote still does not work and you are out of warranty then I would use BUZZTV ARQ-100 REVOLUTIONARY REMOTE CONTROL https://buzztvglobal.com/collections/remotes-keyboards/products/buzztv-arq-100-our-revolutionary-remote-control Quote Link to comment Share on other sites More sharing options...
Chuck13 Posted September 12, 2022 Author Share Posted September 12, 2022 Ok, I guess I should call them. I didnt find any contact info just direction to this postboard. Anyone have contact info for them? Quote Link to comment Share on other sites More sharing options...
Emporium Posted September 12, 2022 Share Posted September 12, 2022 You can either email them at the address below, or use the link right below it.. cs@buzztv.com https://buzztv.com/site/main-contact/ Quote Link to comment Share on other sites More sharing options...
Ryu Posted September 12, 2022 Share Posted September 12, 2022 8 minutes ago, Chuck13 said: Ok, I guess I should call them. I didnt find any contact info just direction to this postboard. Anyone have contact info for them? did you try PC mouse/keyboard? Quote Link to comment Share on other sites More sharing options...
Emporium Posted September 12, 2022 Share Posted September 12, 2022 Just curious, is it just the Bluetooth not working, or the IR also ? Have you tried using a keyboard/mouse to go to menus and unpair the BT100 bluetooth from the unit ? Try also cycling the Bluetooth. For the IR, you can use your cell phone camera, and point the front of the remote towards it, and press a button to see if the IR is working. Most cell phone cameras do not filter IR light sp you should see it light up Quote Link to comment Share on other sites More sharing options...
