Woody Posted August 9, 2022 Share Posted August 9, 2022 Keep getting this error after watching vod and switching back to live tv. Have to refresh server inorder to get it to go away Quote Link to comment Share on other sites More sharing options...
Woody Posted August 9, 2022 Author Share Posted August 9, 2022 On 758 version Quote Link to comment Share on other sites More sharing options...
Ryu Posted August 9, 2022 Share Posted August 9, 2022 I have seen this only once on one server (don't recall server name, randomly picked from online lol) and that happened only on few channels. Quote Link to comment Share on other sites More sharing options...
Woody Posted August 9, 2022 Author Share Posted August 9, 2022 Happens each time i go from vod to live tv Quote Link to comment Share on other sites More sharing options...
Emporium Posted August 9, 2022 Share Posted August 9, 2022 I typically used to go to home screen before clicking on LiveTV, but I just tried it and reproduced it consistently with 758 also. However I did notice one interesting thing.. If I go to VOD and then select "resume" on something I was watching, instead of "Play" to start over, then the error does not occur when switching back to LiveTV. But if I select "Play" (could be on same title), then after a few second switch back to LiveTV it will always give me this error. I tried with at least 3 different channels set on my LiveTV to see if it was specific channel initialization which caused it, and didn't make a difference on which channel I was tuned to on LiveTV when it switched back. Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted August 9, 2022 Share Posted August 9, 2022 1 hour ago, Emporium said: I typically used to go to home screen before clicking on LiveTV, but I just tried it and reproduced it consistently with 758 also. However I did notice one interesting thing.. If I go to VOD and then select "resume" on something I was watching, instead of "Play" to start over, then the error does not occur when switching back to LiveTV. But if I select "Play" (could be on same title), then after a few second switch back to LiveTV it will always give me this error. I tried with at least 3 different channels set on my LiveTV to see if it was specific channel initialization which caused it, and didn't make a difference on which channel I was tuned to on LiveTV when it switched back. How do you switch to Live TV from VOD using Live TV button on remote or pressing back multiple times And which players are setup in Live and VOD Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted August 9, 2022 Share Posted August 9, 2022 We can randomly reproduce this issue if use VLC/Backup Player in VOD and Primary in Live TV, and switch from VOD to Live TV by pressing LIve TV Button on remote now trying to figure out why it happens and fix it 2 1 Quote Link to comment Share on other sites More sharing options...
Woody Posted August 9, 2022 Author Share Posted August 9, 2022 I go to live tv by pressing live tv button and it happens with the primary player Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted August 10, 2022 Share Posted August 10, 2022 This bug was fixed on V759 Sent just now. 3 1 Quote Link to comment Share on other sites More sharing options...
Rinny1 Posted August 10, 2022 Share Posted August 10, 2022 Works great again awesome work !! 1 Quote Link to comment Share on other sites More sharing options...
