PapaS Posted June 4, 2022 Share Posted June 4, 2022 (edited) On x5 box Is there a way to get the weather on the homepage to give me my weather and not the weather of my vpn location? Edited June 4, 2022 by PapaS Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 4, 2022 Share Posted June 4, 2022 I don't think it's possible 1 Quote Link to comment Share on other sites More sharing options...
PapaS Posted June 4, 2022 Author Share Posted June 4, 2022 Thanks a lot @nbs.I was just curious as I run vpn all the time. Hopefully someone at buzztv could change this in a future update. Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 4, 2022 Share Posted June 4, 2022 Not sure if manual input would be feasible Quote Link to comment Share on other sites More sharing options...
PapaS Posted June 4, 2022 Author Share Posted June 4, 2022 I can't find any other weather settings besides the choice of Celsius or Fahrenheit, but nothing for location. 1 Quote Link to comment Share on other sites More sharing options...
streaming429 Posted July 1, 2022 Share Posted July 1, 2022 On 6/4/2022 at 9:16 AM, PapaS said: On x5 box Is there a way to get the weather on the homepage to give me my weather and not the weather of my vpn location? I’ve only found C & F to change. Looks like it’s ip location based from what I can make of it 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted July 1, 2022 Share Posted July 1, 2022 20 minutes ago, streaming429 said: I’ve only found C & F to change. Looks like it’s ip location based from what I can make of it it's based on your isp location always has been 1 Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted July 8, 2022 Share Posted July 8, 2022 On 7/1/2022 at 6:40 PM, dishuser said: it's based on your isp location always has been Does it have to be? Would be nice to see my local weather, since the feature is there. I, like many others, run my VPN all the time. Does me no good to see another city or country. Quote Link to comment Share on other sites More sharing options...
PapaS Posted July 8, 2022 Author Share Posted July 8, 2022 3 minutes ago, Flyinghigh said: Does it have to be? Would be nice to see my local weather, since the feature is there. I, like many others, run my VPN all the time. Does me no good to see another city or country. One solution @Flyinghigh is to use wolf launcher and install a weatherwidget. I know this isn't a real solution but I like my weather on my home screen too so that works for me. 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted July 8, 2022 Share Posted July 8, 2022 I just pick a server close to me Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted July 8, 2022 Share Posted July 8, 2022 That works dishuser as well. I might not want to be on the closest server all the time, though. Thanks 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted July 8, 2022 Share Posted July 8, 2022 11 minutes ago, Flyinghigh said: That works dishuser as well. I might not want to be on the closest server all the time, though. Thanks in my case it's necessary since my ISP bounces me from toronto to montreal and I'm not near either...lol 1 Quote Link to comment Share on other sites More sharing options...
bubba Posted July 19, 2022 Share Posted July 19, 2022 Maybe it could be added to a wishlist for future update? Don't know, but would be nice. 1 Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted July 19, 2022 Share Posted July 19, 2022 50 minutes ago, bubba said: Maybe it could be added to a wishlist for future update? Don't know, but would be nice. We discussed this internally What we can do is add a Lock Location Feature to Buzz Utilities Basically you have the VPN turned off, let it use your real IP location to get the weather Turn on Lock Location Now no matter if you turn the VPN On or Off It will just use the weather for the Location you locked it to. 2 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted July 19, 2022 Share Posted July 19, 2022 I'm in Niagara but my location is Montreal without a VPN...lol Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted July 19, 2022 Share Posted July 19, 2022 1 minute ago, dishuser said: I'm in Niagara but my location is Montreal without a VPN...lol The weather locater is now based on Longitude/Latitude So am not sure what's going on there Quote Link to comment Share on other sites More sharing options...
dishuser Posted July 19, 2022 Share Posted July 19, 2022 24 minutes ago, allaboutbuzz said: The weather locater is now based on Longitude/Latitude So am not sure what's going on there if I reboot my modem/router it will change to Toronto I have CIK Quote Link to comment Share on other sites More sharing options...
