Rover1 Posted Thursday at 04:37 PM Posted Thursday at 04:37 PM I am setting up a Buzz TV "The Classic" on a Harmony remote. The harmony does not have The Classic listed under their device list. Does anyone know what other Buzz TV player would be close in terms of remote codes. Quote
gig63 Posted Thursday at 04:56 PM Posted Thursday at 04:56 PM any of them i still have xrs 4900 on one remote and it works for my x5 2 Quote
Rover1 Posted Thursday at 05:27 PM Author Posted Thursday at 05:27 PM 34 minutes ago, nbs. said: Buzztv is in their database I know a number of players are but the Classic is not listed. Quote
Emporium Posted Thursday at 06:19 PM Posted Thursday at 06:19 PM (edited) The remote IR codes have not changed for ages... I can use a remote from my 4000 series boxes, with all my 5 Series boxes (including the Classic) and even on the P6 box. Hell, even the old older 3000 series boxes used the same IR codes. So just choose ANY buzz box and it should work fine. Edited Thursday at 06:20 PM by Emporium 3 Quote
allaboutbuzz Posted Thursday at 06:30 PM Posted Thursday at 06:30 PM 10 minutes ago, Emporium said: The remote IR codes have not changed for ages... I can use a remote from my 4000 series boxes, with all my 5 Series boxes (including the Classic) and even on the P6 box. Hell, even the old older 3000 series boxes used the same IR codes. So just choose ANY buzz box and it should work fine. This is correct and good advice Thanks 2 Quote
