Rover1 Posted October 4 Share Posted October 4 I have loaded Nord onto my 4500xrs. It works however I cannot control it. The connection page does not respond to disconnect commands. Anyone have any ideas whether there is an issue with the 4500xrs and Nord? I have an X5 also and there are no problems between it and Nord. Quote Link to comment Share on other sites More sharing options...
Ryu Posted October 4 Share Posted October 4 (edited) do you use mouse cursor? also, try a pc mouse and see if that helps. Edited October 4 by Ryu 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 4 Share Posted October 4 I use ipvanish and last year I had to use cursor 1 Quote Link to comment Share on other sites More sharing options...
Emporium Posted October 4 Share Posted October 4 I know windscribe has 2 versions for Android. One for generic Android boxes, and one for AndroidTV (tagged as for the Nvidia Shield). I always use the AndroidTV version since it is the one that the remote works as expected with it, without needing mouse cursor. I know the Android 9 boxes were not AndroidTV, but either way, it works beter even on those. Try downloading the AndroidTV version and manually install that and see if it is any better. https://downloads.nordcdn.com/apps/android/generic/nordvpn-sideload/latest/v2/NordVPN_TV.apk 1 Quote Link to comment Share on other sites More sharing options...
