Matty Posted December 26, 2021 Share Posted December 26, 2021 Thanks for adding me to this group. I hope to learn alot from all of you. I have the 4900 I have a 2 TB drive installed and connected...my problem is ...how do I download pictures and videos to my box from my android phone ? Quote Link to comment Share on other sites More sharing options...
Ryu Posted December 26, 2021 Share Posted December 26, 2021 you can remotely download using teamviewer and other softwares. you can transfer your picture and video and your pc and then to your box using usb cable. Quote Link to comment Share on other sites More sharing options...
Matty Posted December 26, 2021 Author Share Posted December 26, 2021 So I have to transfer to my PC first...there's no way to go from phone to box ? Quote Link to comment Share on other sites More sharing options...
nbs. Posted December 26, 2021 Share Posted December 26, 2021 put your files in google drive ,then access from the box 1 Quote Link to comment Share on other sites More sharing options...
Ryu Posted December 26, 2021 Share Posted December 26, 2021 you can download team view on your box and your phone. open team viewer in both devices and try to connect them first. once connected you can transfer between your devices. also, try this and see if it works, try using bluetooth option and see if it works. Quote Link to comment Share on other sites More sharing options...
Matty Posted December 26, 2021 Author Share Posted December 26, 2021 Awesome...thank you Ryu. I will give it a try Quote Link to comment Share on other sites More sharing options...
Ryu Posted December 27, 2021 Share Posted December 27, 2021 sure. let us know please. Quote Link to comment Share on other sites More sharing options...
Matty Posted December 27, 2021 Author Share Posted December 27, 2021 It asks for partner ID ? Quote Link to comment Share on other sites More sharing options...
Ryu Posted December 27, 2021 Share Posted December 27, 2021 (edited) if this screen is from your box then partner id should be on phone. once you open up team viewer from your phone you should see id and enter that id here and you should get request to connect on your phone Edited December 27, 2021 by Ryu Quote Link to comment Share on other sites More sharing options...
Matty Posted December 27, 2021 Author Share Posted December 27, 2021 Quote Link to comment Share on other sites More sharing options...
Ryu Posted December 27, 2021 Share Posted December 27, 2021 you have to allow incoming connections from your phone. watch some youtube video about teamviwers Quote Link to comment Share on other sites More sharing options...
Matty Posted December 27, 2021 Author Share Posted December 27, 2021 I shall do that...thank you for your patience and help Quote Link to comment Share on other sites More sharing options...
Ryu Posted December 27, 2021 Share Posted December 27, 2021 no worries. also read this because this will fix your issue. https://www.digitbin.com/fix-partner-not-accept-incoming-connections/ Quote Link to comment Share on other sites More sharing options...
Matty Posted December 29, 2021 Author Share Posted December 29, 2021 Okay I got it. Using send files to tv app. Now how do make sure they are getting sent to my 2 TB removable storage instead of the device ? Quote Link to comment Share on other sites More sharing options...
Ryu Posted December 29, 2021 Share Posted December 29, 2021 once you select destination make sure you select your external storage. worse case you can always copy and past/transfer from internal to external from your box. you will see external storage started to get full. you can go to all apps, file browser and select external device and you will see your stuff there. Quote Link to comment Share on other sites More sharing options...
Ogrish58 Posted July 8, 2022 Share Posted July 8, 2022 Old topic but in case you're still trying there is an app called Feem that you can send files to any device Android/PC/Mac/Iphone/Linux. The free version works perfect for me for 2PC/1 android phone/1 android tablet and the 4900. We can even connect to our Samsung refrigerator lol. There's also a $4.99 annual pro version if needed to customize. Quote Link to comment Share on other sites More sharing options...
