John Schiere Posted August 19, 2024 Posted August 19, 2024 I'm working with the Buzz 6 powerstation for the last couple of days and find that some of things that I'm looking at have a very dark picture. Almost like there is way too much contrast. This problem is most relevant on Kodi movies, stremio and Tivimate. l have tried making adjustment to the picture settings in the "settings" part of the powerstation and also to my TV but nothing seems to help this problem. Everything worked fine on my Buzz 5 which I had running before I installed the Buzz 6. Is there any recomendations that you can give me to help this problem. Quote
dishuser Posted August 20, 2024 Posted August 20, 2024 look in bugs and workarounds thread it was already posted and update didn't address it Quote
Emporium Posted August 20, 2024 Posted August 20, 2024 The option to adjust picture settings was posted in the "BuzzTV6 Application: Wishlist for New Features and Enhancements" thread. Also, keep in mind that this is a BuzzTV forum. There is no specific support for 3rd party apps. If the issue appears using the BuzzTV apps (LiveTV, VOD, TV Series), then that is a different story and will be eventually addressed. But something that is 3rd party app specific is not. 1 Quote
dishuser Posted August 20, 2024 Posted August 20, 2024 is that where I posted about it?lol so many threads about same things 2 Quote
allaboutbuzz Posted August 20, 2024 Posted August 20, 2024 On 8/19/2024 at 11:51 PM, John Schiere said: I'm working with the Buzz 6 powerstation for the last couple of days and find that some of things that I'm looking at have a very dark picture. Almost like there is way too much contrast. This problem is most relevant on Kodi movies, stremio and Tivimate. l have tried making adjustment to the picture settings in the "settings" part of the powerstation and also to my TV but nothing seems to help this problem. Everything worked fine on my Buzz 5 which I had running before I installed the Buzz 6. Is there any recomendations that you can give me to help this problem. Expand Do you have HDR turned on? Quote
Mark7 Posted August 24, 2024 Posted August 24, 2024 I was able to brighten the picture up: Settings-Device Preferences-Display&Sound-HDR-HDR Mode-Vivid Max Brightness-1200 1 Quote
Ryu Posted August 24, 2024 Posted August 24, 2024 On 8/24/2024 at 12:12 PM, Mark7 said: I was able to brighten the picture up: Settings-Device Preferences-Display&Sound-HDR-HDR Mode-Vivid Max Brightness-1200 Expand good job 1 Quote
