pirkaso6688 Posted August 27, 2023 Share Posted August 27, 2023 On its own it goes to small screen just like when from full screen you press the ok button. Xrs4500 It happens very often some times every afew minutes..helpmplease I don't see a setting to fix this..gone thru menus ..thanks Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 27, 2023 Share Posted August 27, 2023 Is this recent? Did it happen after the update? post your current firmware and iptv version Quote Link to comment Share on other sites More sharing options...
Ryu Posted August 27, 2023 Share Posted August 27, 2023 not sure if this will help you but you can try delete server and add again and see if that helps. before you add server, go to settings, buzztv app and clear cache first, and reboot your box then add and see if that helps. if you have only one server and ready to delete server then clear data as well when you clear cache. Quote Link to comment Share on other sites More sharing options...
pirkaso6688 Posted September 24, 2023 Author Share Posted September 24, 2023 Yes I think it happened after the update ..cleared cache..no solution , then someone told me to remove battery from remote..and yes remote was acting Quote Link to comment Share on other sites More sharing options...
Emporium Posted September 25, 2023 Share Posted September 25, 2023 When it happens, do you actually see the channel list, or just the small screen in the corner with nothing else ? Reason I ask is that before the update, on my 4900, "if" I was using primary player, and then while I was in the channel list and selected menu->settings->configuration and changed to backup player and then quickly backed out again to the channel list/full screen (before the backup player initialized/started streaming), under some circumstances the video would be only on the top right. And it was strange, sometimes it was a scaled version of the video (like when in channel listing), but sometimes it was just like a "viewport" on the top right (same size, but was just the top right of the full size image). Switching back to Primary player would go back to normal. I have not tried to reproduce it since the update, but I find the players are more stable since the update. 2 Quote Link to comment Share on other sites More sharing options...
dishuser Posted September 25, 2023 Share Posted September 25, 2023 did you take the 20230913 software update to 5.0.893? Quote Link to comment Share on other sites More sharing options...
