V.890 Beta update is out however there is a bug using it on the XRS4900 when performing a Backup to an external thumb drive. The U5 is not affected, selections are saved to the Root of the selected drive by choice. The U5 Firmware has a new update in addition to the App software .890
Appreciate you sharing this, but it is WAY off topic.
That should have been in a thread of it's own (assuming we allow beta discussions here).  This has nothing to do with player selection 🙂
Thanks Dish, the Firmware and Buzz Beta took care of those Player issues.  I noted the Backup issue only for reference. IN the future I will start another Post for these updates, but in this case when using a certain Provider, some channels would not appear using the Main Player.
Edited by tvlarry
An update went out today to fix channel issues on xc servers
Edited by nbs.
backup only worx to internal not external since it's not the same OS as the u5
