tvlarry Posted August 9, 2023 Share Posted August 9, 2023 After about 5-10 minutes some channels will freeze then restart, others will throw an error "stream unavailable" then start again. Same issue on multiple servers and multiple boxes. It also happens on my XRS4900. Tried using MAC Server, Lock ISP, now removed all links. What happened to the Buzz Technical Forum managed by them ? Quote Link to comment Share on other sites More sharing options...
Ryu Posted August 9, 2023 Share Posted August 9, 2023 (edited) might be your isp/servers related then if happening on multiple boxes and servers. your servers might not be great. Switch provider if possible, swap equipment, have them check their system/wirings, use vpn if possible. does not sounds like box related issue at all as nothing happening to my boxes using multiple servers. and nothing happened to Buzz technical forum as they are providing full support. Edited August 9, 2023 by Ryu Quote Link to comment Share on other sites More sharing options...
Emporium Posted August 9, 2023 Share Posted August 9, 2023 I have no issues on my 4500, 4900 X5, Classic or U5 with both servers I use. 1 is MAC and the other XC. If using XC, try going into menu->settings->configuration and at the bottom, change the stream type from TS to HLS and see if that is any better. Like Ryu mentioned, it doesn't sound like a box issue if you are having the issue on more than one box. Did you try power cycling your modem/router just in case ? Quote Link to comment Share on other sites More sharing options...
dishuser Posted August 9, 2023 Share Posted August 9, 2023 obviously nothing happened seeing as you just posted on it 1 Quote Link to comment Share on other sites More sharing options...
tvlarry Posted August 9, 2023 Author Share Posted August 9, 2023 Unlinked MAC & ISP Lock, installed ipvanish, did help for sure. There are still some Starz channels mimicking the same issue but they have always been like this. Since this is a new issue I would assume its a provider issue. It is easy to attack any outgoing web access to a .ru Russia controlled interface, so I am to assume the provider has started this. Quote Link to comment Share on other sites More sharing options...
Emporium Posted August 9, 2023 Share Posted August 9, 2023 Many ISP, in many different countries are doing this. Some just throttle to the point it is unusable, others block all or some streams completely. In most cases, a VPN will help bypass these restrictions. Quote Link to comment Share on other sites More sharing options...
Kwame Posted August 15, 2023 Share Posted August 15, 2023 I 'm having with my U5 box. The light indicator is always showing red after rebooting my box. Therefore, l can't control the box with my remote again. l have unplugging the power on several times but the same problem persist. Thanks Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 15, 2023 Share Posted August 15, 2023 If you have a drive installed pull it out and see if issue continues Quote Link to comment Share on other sites More sharing options...
