roadrunnericu Posted May 25, 2023 Posted May 25, 2023 my 4900 keeps rebooting and often gives an error message that buzztv has stopped responding. i have factory reset the box twice. any help would be appreciated. Quote
nbs. Posted May 25, 2023 Posted May 25, 2023 (edited) Could be power supply, bad hdmi. Try clearing cache too Have you done a hard reset or soft? Edited May 25, 2023 by nbs. 1 Quote
roadrunnericu Posted May 25, 2023 Author Posted May 25, 2023 i changed hdmi ports and cables. check, did not help. i clean the cache and memory often. check, did not help power supply. ill give it a go, thanks. Quote
Ryu Posted May 25, 2023 Posted May 25, 2023 check your power outlet also to make sure its not hot, neutral, reverse...etc Quote
dishuser Posted May 25, 2023 Posted May 25, 2023 1 hour ago, roadrunnericu said: i changed hdmi ports and cables. check, did not help. i clean the cache and memory often. check, did not help power supply. ill give it a go, thanks. if not using the original it needs to be 12 volts 2 Quote
Emporium Posted May 26, 2023 Posted May 26, 2023 If you try all that and you still have issues, as a "test", remove any media you may have installed in the unit (SD card, Hard drive, USB stick). If there is corruption on the media, it may cause strange behaviours. 1 Quote
