Kroach2159 Posted February 14, 2021 Posted February 14, 2021 I have approx 180 MPBS household wifi. My Vistick only shows approx 4-8 MPBS most times.. IS there anything I can do to maximize WiFI Quote
allaboutbuzz Posted February 22, 2021 Posted February 22, 2021 On 2/14/2021 at 1:22 AM, Kroach2159 said: I have approx 180 MPBS household wifi. My Vistick only shows approx 4-8 MPBS most times.. IS there anything I can do to maximize WiFI How strong is the WiFi signal on your stick? Are you using 2.4ghz connection or 5ghz for Wifi? Quote
allaboutbuzz Posted March 12, 2021 Posted March 12, 2021 3 hours ago, Kroach2159 said: 5 GHZ Using your Phone Have it connected to the same Wifi Connection as the stick. Open the Browser/Chrome on both devices Go to Fast.com And compare the speeds of the stick to your phone. To see how big of a difference there is. Also another thing to consider, is to check the Wifi Signal Meter on the stick itself. In most cases, the slower speeds could be the result of a low signal. Quote
Ryu Posted March 12, 2021 Posted March 12, 2021 also make sure your are not on single channel. when you do the speed test make sure you are not running any streaming devices and select your isp's server. Quote
dishuser Posted March 12, 2021 Posted March 12, 2021 1 hour ago, Ryu said: also make sure your are not on single channel. when you do the speed test make sure you are not running any streaming devices and select your isp's server. that won't get you accurate results Quote
