cyrowth Posted February 14, 2023 Posted February 14, 2023 I have an X5 with all the latest updates. A few days ago, my wife's favorite channel started asking for a password to unlock it before it will display. Also, a new entry list right under Favorites appeared labeld Locked Channels which contains 1 channel (wife's favorite). The channel plays fine in TiviMate, so I assume this is a Buzz constraint -- maybe a parental control. We have never setup any parental controls as a 2 adult household, so have no known password to unlock it. Is there a default P/W in case something was done inadvertently to lock the channel ? Is there any way to remove the lock on this 1 channel without knowing the password ? Any help would be appreciated. Quote
nbs. Posted February 14, 2023 Posted February 14, 2023 To get into locked channels use 0000 Once on that channel unlock it 1 Quote
cyrowth Posted February 14, 2023 Author Posted February 14, 2023 (edited) Thanks, that worked. Edited February 14, 2023 by cyrowth Quote
Arty Art Posted July 30, 2023 Posted July 30, 2023 Thank you that worked for me also. Good thing it was my discovery channel and it was locked for long time till I finally looked it up and found your answer. Thank you 1 Quote
dishuser Posted July 30, 2023 Posted July 30, 2023 there's a toolbar at the bottom showing what the coloured buttons do Quote
Emporium Posted February 9, 2024 Posted February 9, 2024 Glad it worked for you... But you didn't need to bump a 6 month old thread Quote
Beachdude Posted December 9, 2024 Posted December 9, 2024 On 2/8/2024 at 7:54 PM, Emporium said: Glad it worked for you... But you didn't need to bump a 6 month old thread Is there a way to change the default PW from 0000 to my own defined code? Quote
pugsycan Posted December 9, 2024 Posted December 9, 2024 1 hour ago, Beachdude said: Is there a way to change the default PW from 0000 to my own defined code? Yes Menu settings Parental control 2 Quote
