jbana48 Posted December 22, 2022 Posted December 22, 2022 4500XRS.. How do I Upgrade From BuzzTV4 Beta firmware to BuzzTV5 Beta firmware? Quote
nbs. Posted December 22, 2022 Posted December 22, 2022 check update and post what firmware is currently on your buzz also post buzz version Quote
dishuser Posted December 22, 2022 Posted December 22, 2022 36 minutes ago, jbana48 said: 4500XRS.. How do I Upgrade From BuzzTV4 Beta firmware to BuzzTV5 Beta firmware? no such thing as beta for either version Quote
Emporium Posted December 23, 2022 Posted December 23, 2022 Odds are, if you do a factory reset on the box, it may automatically upgrade to BuzzTV 5 when it comes back up. I have 2 buddies that wanted to upgrade. They did a factory reset to start clean and the boxes automatically upgraded. 2 Quote
jbana48 Posted December 23, 2022 Author Posted December 23, 2022 I will try to reset & post the result. Problem is they sat it can't be reverted back in case there's a problem 1 Quote
Emporium Posted December 23, 2022 Posted December 23, 2022 That is correct. You can't revert back. It's one way. Quote
