Woody Posted October 22, 2022 Share Posted October 22, 2022 Issue with live tv not starting properly. Am on current update . I press live tv and it goes through the loading and then stalls at user profile intil i hit guide then finishes the loading Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 22, 2022 Share Posted October 22, 2022 try clearing cache cause mine loads fine Quote Link to comment Share on other sites More sharing options...
Ryu Posted October 22, 2022 Share Posted October 22, 2022 yup same here loads perfect fine. Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 22, 2022 Share Posted October 22, 2022 what version is your current update? Quote Link to comment Share on other sites More sharing options...
nbs. Posted October 22, 2022 Share Posted October 22, 2022 11 hours ago, Woody said: Issue with live tv not starting properly. Am on current update . I press live tv and it goes through the loading and then stalls at user profile intil i hit guide then finishes the loading That could be a server issue too Quote Link to comment Share on other sites More sharing options...
Woody Posted October 22, 2022 Author Share Posted October 22, 2022 Im on 779 i have cleared cache and a reset still have same issue . Am on 779 withb new firmware update started happening after the 779 update Quote Link to comment Share on other sites More sharing options...
nbs. Posted October 22, 2022 Share Posted October 22, 2022 54 minutes ago, Woody said: Im on 779 i have cleared cache and a reset still have same issue . Am on 779 withb new firmware update started happening after the 779 update Have you contacted your service and asked them to reset your mac? 1 Quote Link to comment Share on other sites More sharing options...
Woody Posted October 22, 2022 Author Share Posted October 22, 2022 Its not my server its the update . It only happens with live tv on boot if i turn it off and start live tv manually it does not happen if it were a server issue it would happen in either mode Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 22, 2022 Share Posted October 22, 2022 wifi or ethernet? Quote Link to comment Share on other sites More sharing options...
TonyC Posted October 22, 2022 Share Posted October 22, 2022 Delete server portal then re-instate server portal. I had some issues and that seemed to help. 1 Quote Link to comment Share on other sites More sharing options...
nbs. Posted October 22, 2022 Share Posted October 22, 2022 46 minutes ago, Woody said: Its not my server its the update . It only happens with live tv on boot if i turn it off and start live tv manually it does not happen if it were a server issue it would happen in either mode Then reset your box because the update works fine Quote Link to comment Share on other sites More sharing options...
Woody Posted October 22, 2022 Author Share Posted October 22, 2022 Already reset it twice... when i boot box up it has a dialoge box pop up briefly then dissappears. Its as if the update did not install properly i even unisyalled update and let it reinstall same issue happens i am on ethernet. Quote Link to comment Share on other sites More sharing options...
nbs. Posted October 23, 2022 Share Posted October 23, 2022 1 hour ago, Woody said: Already reset it twice... when i boot box up it has a dialoge box pop up briefly then dissappears. Its as if the update did not install properly i even unisyalled update and let it reinstall same issue happens i am on ethernet. I get the same dialog box but no issues Quote Link to comment Share on other sites More sharing options...
