Chris Thomas Posted October 11, 2022 Share Posted October 11, 2022 I'm hoping for some assistance. Most of the channels it seems the audio gets off after a few minutes. Only way to fix is to refresh the channel. I'm using a sound bar connected via HDMI to my tv. X5 is also connected via HDMI to my tv. The second issue is I have installed two different screen saver apps and neither of them will work. Thanks for any ideas. Quote Link to comment Share on other sites More sharing options...
gig63 Posted October 11, 2022 Share Posted October 11, 2022 In live tv click on menu, settings, configuration and in video play try the other player. I had the same problem when i hooked up to my receiver and found backup works best for me Quote Link to comment Share on other sites More sharing options...
Ryu Posted October 11, 2022 Share Posted October 11, 2022 if you dont see improvement with above solution then try to bypass surround bar and see if it plays fine on tv. Quote Link to comment Share on other sites More sharing options...
Chris Thomas Posted October 13, 2022 Author Share Posted October 13, 2022 So I have been using backup player the last few days. That seems to have worked. The backup player doesn't have time shift though which is sad. Thanks guys Quote Link to comment Share on other sites More sharing options...
cyrowth Posted October 15, 2022 Share Posted October 15, 2022 Chris, I am having similar audio sync issues with the Buzz X5 app with primary player. TiviMate with MX Player Pro on my X5 does not seem to exhibit this issue . For me, it makes watching live TV a total PITA having to refresh the channel. Sometimes it can be a only slight mis-sync and we can live with it, other times it is totally disruptive and we have to switch to TiviMate or my other Android TV device. I also find that the secondary player is better from an audio sync standpoint, but it doesn't seem to have as good a picture as the primary player. I will give it a longer trial and see if this impression persists. Wish there was an option to select MX Player Pro or VLC as an external player. Could be that one or both of these are the Buzz "built-in" players, but I have not seen this info anywhere on the blog. Not sure what technical issue could be the cause of this audio sync issue ? Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 15, 2022 Share Posted October 15, 2022 13 minutes ago, cyrowth said: Chris, I am having similar audio sync issues with the Buzz X5 app with primary player. TiviMate with MX Player Pro on my X5 does not seem to exhibit this issue . For me, it makes watching live TV a total PITA having to refresh the channel. Sometimes it can be a only slight mis-sync and we can live with it, other times it is totally disruptive and we have to switch to TiviMate or my other Android TV device. I also find that the secondary player is better from an audio sync standpoint, but it doesn't seem to have as good a picture as the primary player. I will give it a longer trial and see if this impression persists. Wish there was an option to select MX Player Pro or VLC as an external player. Could be that one or both of these are the Buzz "built-in" players, but I have not seen this info anywhere on the blog. Not sure what technical issue could be the cause of this audio sync issue ? it's been posted many times that vlc is one of the video players Quote Link to comment Share on other sites More sharing options...
cyrowth Posted October 15, 2022 Share Posted October 15, 2022 Is VLC the primary or secondary player ?? Do you know what the other Buzz player is ?? Quote Link to comment Share on other sites More sharing options...
nbs. Posted October 15, 2022 Share Posted October 15, 2022 Vlc is an external player which can be used in buzz 5 Quote Link to comment Share on other sites More sharing options...
cyrowth Posted October 15, 2022 Share Posted October 15, 2022 nbs, can you outline the steps to set an external player in the X5 ?? Quote Link to comment Share on other sites More sharing options...
Ryu Posted October 15, 2022 Share Posted October 15, 2022 open buzztv app, press menu, configuration, vod+tv series, select external Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 15, 2022 Share Posted October 15, 2022 3 hours ago, cyrowth said: Is VLC the primary or secondary player ?? Do you know what the other Buzz player is ?? primary Quote Link to comment Share on other sites More sharing options...
Ryu Posted October 15, 2022 Share Posted October 15, 2022 for live tv, open buzztv app, press menu, configuration, live tv, select primary Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 15, 2022 Share Posted October 15, 2022 35 minutes ago, Ryu said: for live tv, open buzztv app, press menu, configuration, live tv, select primary they know that Quote Link to comment Share on other sites More sharing options...
