Kray Posted October 2, 2022 Share Posted October 2, 2022 Hello everyone, I just tried to record my first program and have a run into an issue. The PVR shows that the program was recorded. However when I try to play it nothing happens not quite sure what is going on My buzz box has the latest update. Any help appreciated. Thanks..... Quote Link to comment Share on other sites More sharing options...
nbs. Posted October 2, 2022 Share Posted October 2, 2022 Are you on buzz 4 or 5? Hit the menu button and post the info at bottom Quote Link to comment Share on other sites More sharing options...
Kray Posted October 2, 2022 Author Share Posted October 2, 2022 Quote Link to comment Share on other sites More sharing options...
Kray Posted October 2, 2022 Author Share Posted October 2, 2022 Version:4.0.530. Updated 7/12/2022 Quote Link to comment Share on other sites More sharing options...
nbs. Posted October 2, 2022 Share Posted October 2, 2022 I would recommend you update to buzz 5 After checking for update enter 2015 on remote 1 Quote Link to comment Share on other sites More sharing options...
Kray Posted October 2, 2022 Author Share Posted October 2, 2022 (edited) I clicked on Menu - Check Updates Got a screen message “No updates Available” I then entered 2015 on the remote and clicked OK but nothing happened. Edited October 2, 2022 by Kray Quote Link to comment Share on other sites More sharing options...
nbs. Posted October 2, 2022 Share Posted October 2, 2022 are you checking for update from home page? post the firmware it says when you check update Quote Link to comment Share on other sites More sharing options...
Ryu Posted October 2, 2022 Share Posted October 2, 2022 4 minutes ago, Kray said: I clicked on Menu - Check Updates Got a screen message “No updates Available” I then entered 2015 on the remote and clicked OK but nothing happened. try few times and if nothing then exit out and reboot and try again see if that helps. if nothing send pm to allaboutbuzz with your Mac info. 1 Quote Link to comment Share on other sites More sharing options...
Kray Posted October 2, 2022 Author Share Posted October 2, 2022 from Home Screen Current Firmware version: V20211108 current IPTV Version: 4.0.530 when I click Check Update…..nothing happens I entered 2015 and got message “there is no beta update available on your XRS4500 Max . Quote Link to comment Share on other sites More sharing options...
nbs. Posted October 2, 2022 Share Posted October 2, 2022 Send allaboutbuzz a pm with your mac addy and firmware version He'll add it to the update list He'll be here tomorrow Quote Link to comment Share on other sites More sharing options...
Kray Posted October 2, 2022 Author Share Posted October 2, 2022 Will do thank you! 1 Quote Link to comment Share on other sites More sharing options...
Kray Posted October 2, 2022 Author Share Posted October 2, 2022 Will do thank you! Quote Link to comment Share on other sites More sharing options...
