Rover1 Posted April 18, 2020 Share Posted April 18, 2020 I have a new XRS4500. I have been trying to set the screen resolution to auto switch to best resolution. When I am in advanced settings-Display-screen resolution and I try to set the switch to auto the screen of the XRS goes blank and I have to turn the unit off and back on to get the picture back. When I check to see if the resolution is set to auto it is not. How do I do this? Quote Link to comment Share on other sites More sharing options...
nbs. Posted April 18, 2020 Share Posted April 18, 2020 there seems to be a glitch which will be fixed It wasnt an issue when i set my box up The same thing happened to me when i turned it off and tried to turn it back on I might have a workaround for now after the screen goes black wait a few seconds,then hit the right arrow button and then ok Quote Link to comment Share on other sites More sharing options...
nbs. Posted April 18, 2020 Share Posted April 18, 2020 Actually the workaround didnt work Quote Link to comment Share on other sites More sharing options...
Rover1 Posted April 19, 2020 Author Share Posted April 19, 2020 Thanks for the advice. I tried the suggestion but it did not work for me either. Hopefully there will be a fix with a new firmware update. Quote Link to comment Share on other sites More sharing options...
nbs. Posted April 19, 2020 Share Posted April 19, 2020 It shouldn't be too long They are working on a new file now Quote Link to comment Share on other sites More sharing options...
