nbs. Posted July 23, 2022 Posted July 23, 2022 Mate1 uses buzz 2 software What is on your box now? 1 Quote
iboxey Posted September 24, 2022 Author Posted September 24, 2022 Hi thanks for replying sorry for long delay. I am stuck with quite a few Mate1 boxes for that is the my main reason to have a original firmware on hand . I had one but I can't located anymore. one box keep popping up "Bluetooth share keeps stopping" Another one is stuck on red light front of the box and tv doesn't detect please help me finding the any firmware whichever will work with Mate I "boomerang" Thankks Quote
dishuser Posted September 24, 2022 Posted September 24, 2022 also you never posted what firmware/software versions are you won't find that under about Quote
iboxey Posted September 24, 2022 Author Posted September 24, 2022 Reset yes few times from recovery Quote
iboxey Posted September 24, 2022 Author Posted September 24, 2022 and ver 7.1.2 build v20191111.20191111 test-keys kernal ver 3.14.29 dev_user@builder #1 mon nov 11 Quote
Ryu Posted September 24, 2022 Posted September 24, 2022 5 minutes ago, iboxey said: and ver 7.1.2 build v20191111.20191111 test-keys kernal ver 3.14.29 dev_user@builder #1 mon nov 11 hes asking for buzz application information Quote
dishuser Posted September 24, 2022 Posted September 24, 2022 15 minutes ago, iboxey said: and ver 7.1.2 build v20191111.20191111 test-keys kernal ver 3.14.29 dev_user@builder #1 mon nov 11 I said you won't find them in about press menu button in live tv version 2.0 or 1.6? version 352? Quote
Ryu Posted September 24, 2022 Posted September 24, 2022 https://mega.nz/file/CQNEybab#rF2YQmvphIB_5j7KTjdKnGYcvNw4_8yHzrASAXqAbLs 2 Quote
dishuser Posted September 24, 2022 Posted September 24, 2022 2 minutes ago, iboxey said: Ver 2.0 (333) Date11.06... if software won't update from live tv that means it's not on server Quote
iboxey Posted September 24, 2022 Author Posted September 24, 2022 Ok Thanks , Ryu it is same file 2.0 333 https://mega.nz/file/CQNEybab#rF2YQmvphIB_5j7KTjdKnGYcvNw4_8yHzrASAXqAbLs Dishuser Thanks , if software won't update from live tv that means it's not on server Basically You are saying I am screwed and stuck with Lemon Kangaroo boxes I have more then 40 and every new box I open it has some new Issues third one brand new I Just opened does not work with ethernet. I am sure buzz have some kind of backup Just hoping for People at Buzz find little time from there buzzy schedule for me. Quote
dishuser Posted September 24, 2022 Posted September 24, 2022 4 minutes ago, iboxey said: Ok Thanks , Ryu it is same file 2.0 333 https://mega.nz/file/CQNEybab#rF2YQmvphIB_5j7KTjdKnGYcvNw4_8yHzrASAXqAbLs Dishuser Thanks , if software won't update from live tv that means it's not on server Basically You are saying I am screwed and stuck with Lemon Kangaroo boxes I have more then 40 and every new box I open it has some new Issues third one brand new I Just opened does not work with ethernet. I am sure buzz have some kind of backup Just hoping for People at Buzz find little time from there buzzy schedule for me. email them cs@buzztv.com and let them know about your issues Quote
nbs. Posted September 24, 2022 Posted September 24, 2022 The file Ryu posted is not 333 It's 2.0 352 2 Quote
iboxey Posted October 7, 2022 Author Posted October 7, 2022 https://mega.nz/file/CQNEybab#rF2YQmvphIB_5j7KTjdKnGYcvNw4_8yHzrASAXqAbLs It's not 2.0 352 I have downloaded and install from above link and it is 333 and not 2.0 352 Quote
nbs. Posted October 7, 2022 Posted October 7, 2022 (edited) 22 minutes ago, iboxey said: https://mega.nz/file/CQNEybab#rF2YQmvphIB_5j7KTjdKnGYcvNw4_8yHzrASAXqAbLs It's not 2.0 352 I have downloaded and install from above link and it is 333 and not 2.0 352 After downloading it did you go to menu ,check updates? I know several people who loaded the file and it was 352 Edited October 7, 2022 by nbs. 1 Quote
Emporium Posted October 10, 2024 Posted October 10, 2024 I just got my buddies Boomerang Mate 1 to try to update it (has been powered off for ages), but obviously nothing on server (not surprised consider how old it is). Current state is: V20190207 with V2.0(239) presently installed. Did a hard factory reset ,I tried installing the buzz 352 software (as posted above) which I already had and used to update his (and mine) old xpl3000 [and had no issues with the xpl3000 units], but it gives me an error "BuzzTV 2, App not installed. The package conflicts with an existing package by the same name". Tried installing from Appinstaller and File Browser that are preinstalled. Not sure what package it doesn't like, because the main package on the mate1 seems to be com.boomerang.* while the buzz ones (including 352, are com.buzztv.*. So maybe it is some common dependencies. All I really wanted to do is install a later version of BuzzTV 2, so he has the "streaming line" option, to be able to use it with w$%^#d and XC connection. The xpl3000 after updating to 352 and enabling streaming line and credentials works fine. A little slow (by todays standards), but it works quite well. Even tried checking recovery screen if there was some way to install the apk by forcing it, but I did not find anything. However when I used to have an old boomerang myself, I could have sworn I had taken an update which pretty much rebranded it to a buzz box, and even replaced the boomerang logo on the top left with a buzz logo. If that update was still available somehow for use with a microsd card to update the box, that would be great. I really don't want to install something like "smar..." app to use it with XC API. 1 Quote
Emporium Posted October 17, 2024 Posted October 17, 2024 Damn... All I have to say to Buzz team is WOW & huge thanks with this old box. Emailed CS, and after a little back and forth and nearly had just given up (not a biggie since it is an old box), they came through. They managed to find the last firmware they sent out to the MATE 1 (which essentially rebranded it to a Buzz) and they sent me it, I managed to install it with a USB key through recovery and the box now works like a charm. The firmware brings the box up to Firmware V20200326 with S/W version 2.0 (354). I just remembered, they also sent me the APK for (357) which was the last version the released for the MATE1 I believe. I did not try it after the firmware update (since tried it before the firmware update and it would not work due to other API/dependency issues). Tested it with MAC/ XC and M3U and works fine now. I have asked for permission and was given the OK, and I will upload the file (probably later this weekend) to the Downloads section of this forum in case anyone else wants to dust off the old box and give it a new life. Thanks again BUZZ team 4 Quote
iboxey Posted October 19, 2024 Author Posted October 19, 2024 Thanks for doing favors to other's members. I will be keep checking for your uploads. if you can, please message to me once you upload the files thanks 1 Quote
Emporium Posted October 19, 2024 Posted October 19, 2024 I'll try to up it later this weekend or Monday. Taking advantage of the nice weather to finish some of my outdoor stuff I need to do before winter. 1 Quote
