Ryu Posted July 11, 2022 Posted July 11, 2022 very useful information https://buzztv.com/site/smart-remote/ Â Quote
dishuser Posted September 13, 2022 Posted September 13, 2022 there's 3 ways to pair remote use the app settings/remotes and accessories hold info button down until it pops up to pair 1 Quote
timwadesings@yahoo.com Posted July 3, 2023 Posted July 3, 2023 I hate the slow response of the BT-400 with my X-5. I think it's the blue tooth ability. I was told that it can be converted to IR but I cannot find any info on it. Can somebody tell me where to find it if it is so? The manuals are very brief and very little information. Quote
Emporium Posted July 3, 2023 Posted July 3, 2023 Slow response ? Mine in pretty instantaneous, even with BT paired. Just go into "remotes and accessories" in the settings, and UNPAIR the remote. You can then just point it to the box to use the IR.  2 Quote
Emporium Posted July 3, 2023 Posted July 3, 2023 Do you have your WiFi router close to your buzz box ? Don't forget that BT and WiFi both operate on 2.4Ghz.  Try changing the 2.4Ghz channel on your WiFi router if you are relatively close (channel 1, 6 or 11 to ensure non overlapping channels). There may be an interference. I would tell you to disable 2.4Ghz and stick to 5Ghz band only, but many IoT devices are 2.4Ghz only.  1 Quote
