streaming429 Posted June 29, 2022 Posted June 29, 2022 (edited) I have exhausted every way possible that I know of to pair my TCL Roku TV with the BT-400 and it just won’t happen. Any suggestions? Edited June 29, 2022 by streaming429 Misspell Quote
dishuser Posted June 29, 2022 Posted June 29, 2022 did you enter 5 for the code when manually setting up? Quote
streaming429 Posted June 29, 2022 Author Posted June 29, 2022 I tried both manually and using 5. Went through the 14 codes when doing the auto pair as well. Thanks Quote
dishuser Posted June 29, 2022 Posted June 29, 2022 unfortunately according to manual 5 is the code for tcl maybe allaboutbuzz might have a fix Quote
allaboutbuzz Posted June 29, 2022 Posted June 29, 2022 8 hours ago, streaming429 said: I have exhausted every way possible that I know of to pair my TCL Roku TV with the BT-400 and it just won’t happen. Any suggestions? Please PM me We will get someone to call you 2 2 Quote
streaming429 Posted July 3, 2022 Author Posted July 3, 2022 On 6/29/2022 at 3:24 PM, allaboutbuzz said: Please PM me We will get someone to call you Nobody has called and I’ve spent another two days trying to pair it to no avail Quote
dishuser Posted July 3, 2022 Posted July 3, 2022 44 minutes ago, streaming429 said: Nobody has called and I’ve spent another two days trying to pair it to no avail yesterday was a holiday now it's the weekend 1 Quote
streaming429 Posted July 3, 2022 Author Posted July 3, 2022 31 minutes ago, dishuser said: yesterday was a holiday now it's the weekend I understand that. You posted on Wed and I was just letting you know it hasn’t been resolved Quote
dishuser Posted July 3, 2022 Posted July 3, 2022 2 minutes ago, streaming429 said: I understand that. You posted on Wed and I was just letting you know it hasn’t been resolved I never expected it to be resolved by now you must not realize there are people ahead of you that sent in emails or submitted a ticket Quote
streaming429 Posted July 3, 2022 Author Posted July 3, 2022 1 hour ago, dishuser said: I never expected it to be resolved by now you must not realize there are people ahead of you that sent in emails or submitted a ticket Thanks for letting me know. I appreciate it. I just did not interpret it in that way from your first response. My apologies 1 1 Quote
mwtiu2000 Posted November 28, 2022 Posted November 28, 2022 Same issue. I just posted in the bt400 forum. Any updates? Quote
allaboutbuzz Posted November 29, 2022 Posted November 29, 2022 16 hours ago, mwtiu2000 said: Same issue. I just posted in the bt400 forum. Any updates? Since its a Roku TV That is why it does not work. We confirmed this with our remote factory. Quote
mwtiu2000 Posted November 30, 2022 Posted November 30, 2022 Are there any universal bluetooth + IR remotes on the market that are known to work with the U5? Quote
mwtiu2000 Posted December 1, 2022 Posted December 1, 2022 I apologize for not using the quote button with these replies, it does nothing when I push it and Ive tried 3 different browsers. "Get a BT250 " -gig63 Is that remote proven to pair with a TCL tv with Roku operating system? "Since its a Roku TV. That is why it does not work. We confirmed this with our remote factory." -allaboutbuzz Honestly its just an infared signal...basically blinking a code...whether Roku OS or not. Im not asking for a source input button or anything Roku specific, just volume up/down/mute. If you guys aren't willing to ask the remote control factory people to; A: Add a one button autoscan in learning mode to try 100's of different codes a few seconds apart or B: Add and IR input function to clone individual button pushes of any IR remote ...if neither of those...can you at least create an app that allows a universal BT/IR remote (https://www.sofabaton.com/u1.html for example) to be mapped to work with your OS? If I cant pair your remote to my TCL Roku tv, I can pair a nice universal remote to the TCL and bluetooth pair it with your box, then map it via an app you'd support. thanks, Matt Quote
Emporium Posted December 1, 2022 Posted December 1, 2022 (edited) The BT-250 remote uses a different concept that the BT300/400 remotes (it is similar to the IR100/IR200/BT100/BT200 remotes). The buttons on the top that you see in the image below that are surrounded with a BLUE line are IR learning buttons. On the 100 series remotes you only have 2 buttons (TV power, and source), on the 200 series remotes, you have 4 buttons (TV Power, TV source, TV VOL+ and TV VOL-). The programming is primitive, but it works well. You put the remote in learn mode, you press the button you want to program, then you take your original remote, point it to the front (IR) of the buzz remote and you press it for it to learn it. In reality, you can program them all to do what you want. If you don't care for the "TV source" button, you can program it to be "TV mute" if you want. On my BT200 I have programmed the VOL buttons in reverse. VOL- I programmed as VOL+ and vice versa. You may think it is nuts, but I have a preference and I'm used to having VOL+ to the right of a VOL- button. So regardless of what the buttons say, muscle memory will always click the right button to increase volume, and left button to decrease I don't have a Roku TV, so I can't confirm 100% that it will work with your IR remote, but I don't see why not. I have a small 20+yr old Audiovox LCD TV (one of the first). I could never get any universal remote (I tried piles of URC, OneForAll, RCA, etc.. ) remotes and none had a code which worked for this TV (never tried a harmony). But I managed to use the original remote (which still partially works) and programmed a Buzz IR200 remote with the power button for the TV, and Volume controls (don't need the source button). Keep in mind that if your TV needs more than a single keypress to cycle through "input sources", then the source button will be useless for that purpose. ie: if your TV requires you to click on a button to bring up the sources, then use a d-pad to select the source you want and then possibly even require you to hit OK before it switches, then it will not work. This TV source button is for TVs that use a single discrete code to cycle through the various input sources. If you want, check out my post in another thread, I posted a manual for the BT-250 in PDF format. You will see how the process goes about to program the learn keys. https://stbtalk.com/index.php?/topic/5646-bt-250-remote/&do=findComment&comment=18958 I've seen the sofabaton remotes. They look nice (and with the end of the harmony remotes they are pretty much the best option), but they are not cheap. They will cost as much as the buzz box itself I don't know if they support the buzz boxes, but I am sure they would be open to add support if they had the codes needed. Edited December 1, 2022 by Emporium Quote
gig63 Posted December 1, 2022 Posted December 1, 2022 I have the BT 200 with the x5 and yes I got it so it will turn the tv on and works my sound bar Quote
22 Milez Away Posted May 31, 2024 Posted May 31, 2024 Hi. I just got the U5 with the BT-400. I have a pretty new TCL and I followed directions to pair, but no luck. Any help would be greatly appreciated. Quote
allaboutbuzz Posted May 31, 2024 Posted May 31, 2024 43 minutes ago, 22 Milez Away said: Hi. I just got the U5 with the BT-400. I have a pretty new TCL and I followed directions to pair, but no luck. Any help would be greatly appreciated. Most TCL TVs don't offer IR Codes So that is probably why it doesn't work 3 1 Quote
Gary9 Posted July 7, 2024 Posted July 7, 2024 Hello, I bought one TCL Qled recently ,I followed the step to program and worked using code #5 and it works Accidentally I found that the TV's remote controls the Buzztv x5 also. My TCL tv is one month old and is a google tv. Quote
