Comtech Posted June 26, 2022 Share Posted June 26, 2022 hey Guys i’m having a problem recording with my buzz box v5 is there a step by step on how to record programs to it? i’m hit and miss,some of my questions are do you have to leave the box on? and on the channel you want to record? can you record to a usb or sd card? can you use sd card and/or usb to record channels and also use the same card or usb to timeshift? do i have to leave it on the iptv provider to record or can i watch one of the two i have and will it record on the the one i’m not watching at the moment? what’s the best place to store timeshift data? i know…lol alot of questions and i’m testing when i have time but it’s warm outside so the fam is demanding of my time right now thx and Troy is the freakin man!! Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 26, 2022 Share Posted June 26, 2022 a lot depends on whether your service allows one connection or more Menu ,account info will tell you if there is more than one Quote Link to comment Share on other sites More sharing options...
Comtech Posted June 26, 2022 Author Share Posted June 26, 2022 one service allows 2 the other allows 4 but it seems like if i record a show while box and reciever are on and tuned to the channel i want to record? it works but that doesn't seem right to me shouldn't i be able to put the box to sleep and the reciver off and still have it record? anyone else recording iptv using the buzz app have sucess? how are you doing it? thx Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 26, 2022 Share Posted June 26, 2022 (edited) recording and turning off box works on 4900 ill play with recording tonight on the x5 Edited June 26, 2022 by nbs. Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 26, 2022 Share Posted June 26, 2022 (edited) i did record two shows and watch while watching one channel One of the recordings failed but one worked You can hit the red button to start recording immediately I use one button record you can record from guide and either schedule it Always good to add a few minutes Then you can schedulea recording from menu etc Edited June 26, 2022 by nbs. Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 26, 2022 Share Posted June 26, 2022 11 minutes ago, nbs. said: i did record two shows and watch while watching one channel One of the recordings failed but one worked You can hit the red button to start recording immediately I use one button record you can record from guide and either schedule it Always good to add a few minutes Then you can schedulea recording from menu etc same Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 26, 2022 Share Posted June 26, 2022 recording while box is suspended worx though 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 26, 2022 Share Posted June 26, 2022 also when I was watching the channel I was recording it was freezing quite a bit but the recording is flawless 1 Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 26, 2022 Share Posted June 26, 2022 Recording failed when box is shut off 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 26, 2022 Share Posted June 26, 2022 53 minutes ago, nbs. said: i did record two shows and watch while watching one channel One of the recordings failed but one worked You can hit the red button to start recording immediately I use one button record you can record from guide and either schedule it Always good to add a few minutes Then you can schedulea recording from menu etc I figured out why it failed you need more than 2 connections with 2 connections you use both while recording the channel you're watching just tried a server with 4 connections and can do 2 recordings at same time it still causes freezing but recordings are flawless 1 Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 26, 2022 Share Posted June 26, 2022 i have 3 connections when that failed I will be trying again 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 26, 2022 Share Posted June 26, 2022 10 minutes ago, nbs. said: i have 3 connections when that failed I will be trying again I had 2 recordings going and watched a different channel maybe I should push the envelope and add a download at same time if it worx I'll see if I can get the log from service Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 26, 2022 Share Posted June 26, 2022 one recording while watching = 2 two recordings while watching one = 3 three recordings while watching one = 4 but I can watch a channel other than the ones recording and it stays at 4 and freezing has improved greatly one button record is off Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 26, 2022 Share Posted June 26, 2022 the good news is I switched servers and when I went back my recordings were still going 1 Quote Link to comment Share on other sites More sharing options...
Nilo Posted July 13, 2022 Share Posted July 13, 2022 I’m just bought a new xrs4900 my question is can I record my favourite movie but on schedule time I mean the stb is off I tried to record when the stb is off but it is not working Can somebody help me. Thanks Quote Link to comment Share on other sites More sharing options...
nbs. Posted July 13, 2022 Share Posted July 13, 2022 (edited) Hit menu ,what is version number at bottom? Edited July 13, 2022 by nbs. Quote Link to comment Share on other sites More sharing options...
dishuser Posted July 13, 2022 Share Posted July 13, 2022 you need an update pm allaboutbuzz or email cs@buzztv.com your mac addy(server id),model number and current version 1 Quote Link to comment Share on other sites More sharing options...
Nilo Posted July 14, 2022 Share Posted July 14, 2022 My version number is 5.0.626. Updated 11/13/2021 Quote Link to comment Share on other sites More sharing options...
nbs. Posted July 14, 2022 Share Posted July 14, 2022 pm allaboutbuzz and ask for autoupdate also load this pvr file https://www.mediafire.com/file/epmf5i0suejl6rj/com_buzz.services.pvr_33_5056428e-2cad-4bbe-9a31-4e13bdb55857.apk/file Quote Link to comment Share on other sites More sharing options...
Terry Knapper Posted August 6, 2022 Share Posted August 6, 2022 By , say , four connections, do you mean the same playlist from a supplier that allows multiple connections? Terry K Quote Link to comment Share on other sites More sharing options...
Emporium Posted August 6, 2022 Share Posted August 6, 2022 1 hour ago, Terry Knapper said: By , say , four connections, do you mean the same playlist from a supplier that allows multiple connections? Terry K YES, that is exactly what he is referring to. Some suppliers offer multiple connections (2, 3, 4 or more). This will allow you to do multiple recording in parallel. Just keep in mind that each recording is a fork and creates another connection to the server. So watching live TV is one connection and then every simultaneous recording (even if it is the same channel you are watching) is another connection. Quote Link to comment Share on other sites More sharing options...
dishuser Posted August 6, 2022 Share Posted August 6, 2022 4 minutes ago, Emporium said: YES, that is exactly what he is referring to. Some suppliers offer multiple connections (2, 3, 4 or more). This will allow you to do multiple recording in parallel. Just keep in mind that each recording is a fork and creates another connection to the server. So watching live TV is one connection and then every simultaneous recording (even if it is the same channel you are watching) is another connection. watching and recording same channel is one connection Quote Link to comment Share on other sites More sharing options...
Terry Knapper Posted August 6, 2022 Share Posted August 6, 2022 Thank you "Emporium". I use an app that can run multiple play lists at the same time. I guess this entirely different. TK Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 6, 2022 Share Posted August 6, 2022 account info tells you how many connections you have Quote Link to comment Share on other sites More sharing options...
Emporium Posted August 6, 2022 Share Posted August 6, 2022 27 minutes ago, dishuser said: watching and recording same channel is one connection You sure about that ? Even in your post above you stated "with 2 connections you use both while recording the channel you're watching" and this is what I recall when running a few tests back then. Quote Link to comment Share on other sites More sharing options...
