Fred Perso Posted January 13 Posted January 13 Hi there, As many others, I have this error for a month now. m3u is working without problem but for a month now (it worked for almost a year), xc api refuse to load. I checked with my provider. He gave me another url and suddenly it worked.. for 10 sec.! When I left app then get back, same error! Tried with / without vpn it's working with other apps (Tivimate / Implayer) it worked for almost a year then stop working recently (app update?) Cleared data / cache So it definitively comes form the app/box, not my provider Any ideas? Fred 1 Quote
Ryu Posted January 13 Posted January 13 (edited) try to post in the section for your model Edited January 13 by Ryu Quote
allaboutbuzz Posted January 13 Posted January 13 8 hours ago, Fred Perso said: Hi there, As many others, I have this error for a month now. m3u is working without problem but for a month now (it worked for almost a year), xc api refuse to load. I checked with my provider. He gave me another url and suddenly it worked.. for 10 sec.! When I left app then get back, same error! Tried with / without vpn it's working with other apps (Tivimate / Implayer) it worked for almost a year then stop working recently (app update?) Cleared data / cache So it definitively comes form the app/box, not my provider Any ideas? Fred Are the server urls the same for the M3U as the XC Login? Quote
Fred Perso Posted January 14 Author Posted January 14 Yes, same url and infos, just different format Quote
NsC0001 Posted January 19 Posted January 19 My box just updated to a new version and it looks like it fixed the issue Quote
Emporium Posted January 19 Posted January 19 Glad it fixed your problem.. But I don't see anything in the Release notes about XC API. Unless it was very minor that it was fixed, but didn't make the list. ----------------- V5.0.0957 New Buzz 5 App Update Jan 19th, 2026 Changes: - Updated Weather Widget**957** - **Fixed Catch-Up on Mac Servers** - Added New QR/Web Server Feature to Server Settings to allow you to edit or add new servers remotely via Code or QR on website - Fixed Subtitles Bugs - Update Primary and Backup Players ---------------- Quote
MilMascaras Posted January 19 Posted January 19 3 hours ago, Emporium said: Glad it fixed your problem.. But I don't see anything in the Release notes about XC API. Unless it was very minor that it was fixed, but didn't make the list. ----------------- V5.0.0957 New Buzz 5 App Update Jan 19th, 2026 Changes: - Updated Weather Widget**957** - **Fixed Catch-Up on Mac Servers** - Added New QR/Web Server Feature to Server Settings to allow you to edit or add new servers remotely via Code or QR on website - Fixed Subtitles Bugs - Update Primary and Backup Players ---------------- this update are for certain boxes? mine x5 is still on 956. Quote
Emporium Posted January 19 Posted January 19 25 minutes ago, MilMascaras said: this update are for certain boxes? mine x5 is still on 956. Not 100% sure, but my xrs4900, E2, and my Classic all got it so far. Have not powered up the others yet. From LiveTV, did you try going to Menu->Settings->Check updates ? Quote
allaboutbuzz Posted January 19 Posted January 19 25 minutes ago, MilMascaras said: this update are for certain boxes? mine x5 is still on 956. Right now just Android 9 Should get rolled out to Android 11 tomorrow or Wed The update was just to update the Weather Widget though, as that company required some API changes. 4 Quote
allaboutbuzz Posted January 19 Posted January 19 4 hours ago, NsC0001 said: My box just updated to a new version and it looks like it fixed the issue We didnt make any changes to address this though Cannot load server:not supported is a cloudflare issue from the server. 3 Quote
dishuser Posted January 20 Posted January 20 3 hours ago, NsC0001 said: This morning the issue cannot load portal is back try a vpn Quote
Fred Perso Posted January 20 Author Posted January 20 I see that all suggestion point to the fact it's not related to the box/app itself but because of cloudflare. But in that case, how come it worked with same box and provider for a long period of time then suddenly not anymore but it's still working for other app on same box ? If it was on provider side Cloudflare), it shouldn't work at all on xc api, on every app. But it work xc api with other app, and on buzz tv it works on m3u with same credential. I maybe dumb or miss something but I cannot see what cloudflare has to do with that. And vpn has no impact because I tryied with and without and no change. 1 Quote
allaboutbuzz Posted January 20 Posted January 20 9 hours ago, NsC0001 said: This morning the issue cannot load portal is back I PM you Quote
allaboutbuzz Posted January 20 Posted January 20 1 hour ago, Fred Perso said: I see that all suggestion point to the fact it's not related to the box/app itself but because of cloudflare. But in that case, how come it worked with same box and provider for a long period of time then suddenly not anymore but it's still working for other app on same box ? If it was on provider side Cloudflare), it shouldn't work at all on xc api, on every app. But it work xc api with other app, and on buzz tv it works on m3u with same credential. I maybe dumb or miss something but I cannot see what cloudflare has to do with that. And vpn has no impact because I tryied with and without and no change. I PM you Quote
allaboutbuzz Posted January 20 Posted January 20 3 hours ago, Fred Perso said: I see that all suggestion point to the fact it's not related to the box/app itself but because of cloudflare. But in that case, how come it worked with same box and provider for a long period of time then suddenly not anymore but it's still working for other app on same box ? If it was on provider side Cloudflare), it shouldn't work at all on xc api, on every app. But it work xc api with other app, and on buzz tv it works on m3u with same credential. I maybe dumb or miss something but I cannot see what cloudflare has to do with that. And vpn has no impact because I tryied with and without and no change. Try using Fast Login for Login Type instead of Default 2 Quote
