ncsocial Posted November 30, 2019 Share Posted November 30, 2019 I added a server in the buzztv xr 4000 and no EPG DATA populates Quote Link to comment Share on other sites More sharing options...
Nelutz Posted November 30, 2019 Share Posted November 30, 2019 16 minutes ago, ncsocial said: I added a server in the buzztv xr 4000 and no EPG DATA populates ??maybe ur server doesn't have EPG, mine populate ,and I'm trying 4 servers. Quote Link to comment Share on other sites More sharing options...
ncsocial Posted November 30, 2019 Author Share Posted November 30, 2019 I'm using the same server on my formuler z8, my Android TV , my phone and other players and they all have EPG Data Quote Link to comment Share on other sites More sharing options...
Stugots Posted November 30, 2019 Share Posted November 30, 2019 are you using portal (mac address) or streaming lines? Quote Link to comment Share on other sites More sharing options...
ncsocial Posted December 1, 2019 Author Share Posted December 1, 2019 I am using streaming line Quote Link to comment Share on other sites More sharing options...
ncsocial Posted December 1, 2019 Author Share Posted December 1, 2019 Portal URL Username Password Quote Link to comment Share on other sites More sharing options...
Nelutz Posted December 1, 2019 Share Posted December 1, 2019 On 11/30/2019 at 9:57 AM, ncsocial said: I'm using the same server on my formuler z8, my Android TV , my phone and other players and they all have EPG Data This is another problem they should fix on the new update Quote Link to comment Share on other sites More sharing options...
ncsocial Posted December 3, 2019 Author Share Posted December 3, 2019 When will the next update be Quote Link to comment Share on other sites More sharing options...
Nelutz Posted December 3, 2019 Share Posted December 3, 2019 1 hour ago, ncsocial said: When will the next update be From what I read here it should be this week, but who knows Quote Link to comment Share on other sites More sharing options...
ncsocial Posted December 16, 2019 Author Share Posted December 16, 2019 By chance any update with regards to the EPG DATA not populating Quote Link to comment Share on other sites More sharing options...
Nelutz Posted December 16, 2019 Share Posted December 16, 2019 3 hours ago, ncsocial said: By chance any update with regards to the EPG DATA not populating Ask stugots to put you on the beta list ,like that you can try it yourself and see if they fix it or not ,from what I've tried seams like they have been improved. Quote Link to comment Share on other sites More sharing options...
ncsocial Posted December 16, 2019 Author Share Posted December 16, 2019 Im in the beta group but not sure where to access the chat Quote Link to comment Share on other sites More sharing options...
Nelutz Posted December 17, 2019 Share Posted December 17, 2019 9 hours ago, ncsocial said: Im in the beta group but not sure where to access the chat Check the bottom of the page u will see the beta section ,post it there Quote Link to comment Share on other sites More sharing options...
Stugots Posted December 17, 2019 Share Posted December 17, 2019 @ncsocial@Nelutz both of you are on the beta which doesn't have this EPG issue. The public update is being sent today. Quote Link to comment Share on other sites More sharing options...
ncsocial Posted December 17, 2019 Author Share Posted December 17, 2019 Quote Link to comment Share on other sites More sharing options...
Nelutz Posted December 18, 2019 Share Posted December 18, 2019 14 hours ago, Stugots said: @ncsocial@Nelutz both of you are on the beta which doesn't have this EPG issue. The public update is being sent today. I don't have that issue @ncsocial has that ,I just tried to help Quote Link to comment Share on other sites More sharing options...
Nikman Posted January 5, 2020 Share Posted January 5, 2020 I am also having issues with EPG not populating. EPG does show up on android but through the apk so I'm not sure weather this is a problem with the XRS4000 or the provider Quote Link to comment Share on other sites More sharing options...
ncsocial Posted January 11, 2020 Author Share Posted January 11, 2020 The EPG came up but there is a new issue where the channel that's showing blanks out and then comes back every few seconds 1 Quote Link to comment Share on other sites More sharing options...
BigBision Posted January 16, 2020 Share Posted January 16, 2020 On 1/11/2020 at 7:37 AM, ncsocial said: The EPG came up but there is a new issue where the channel that's showing blanks out and then comes back every few seconds lets try this method see if it works, if not then contact your livetv provider for help. 1. Press Menu and Select Exit, 2. Select Live and let it load and check your Channels and EPG. if all good then working, if not then your Livetv provider can check in to it. Quote Link to comment Share on other sites More sharing options...
nbs. Posted January 19, 2020 Share Posted January 19, 2020 you can also hit menu .configuration,clear epg I have 4 servers and no issues with epg on any of them unless its on server end 1 1 Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted January 23, 2020 Share Posted January 23, 2020 On 12/16/2019 at 7:41 AM, ncsocial said: By chance any update with regards to the EPG DATA not populating Are you located in UK? Just asking as we fixed a similar issue of no EPG this week on Closed Beta. Quote Link to comment Share on other sites More sharing options...
ncsocial Posted January 23, 2020 Author Share Posted January 23, 2020 What is the most recent beta update Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted January 23, 2020 Share Posted January 23, 2020 54 minutes ago, ncsocial said: What is the most recent beta update Right now it's in closed Beta 4.0.408 is the latest closed Beta. Quote Link to comment Share on other sites More sharing options...
Logic2019 Posted September 18, 2021 Share Posted September 18, 2021 I've just started having this issue now as well on the XRS 4500. Has it been fixed? I would also like to be in the beta group please! Quote Link to comment Share on other sites More sharing options...
dishuser Posted September 18, 2021 Share Posted September 18, 2021 3 minutes ago, Logic2019 said: I've just started having this issue now as well on the XRS 4500. Has it been fixed? I would also like to be in the beta group please! your title shows you are in beta group no issues with epg here most likely server end or try clearing cache 1 Quote Link to comment Share on other sites More sharing options...
