Nahannz Posted January 1 Posted January 1 7 minutes ago, nbs. said: Wipe data factory reset 26 minutes ago, Ryu said: different model but same procedure Successfully factory reset and rebooted. Where do I find server information for buzztv to gain back access to live TV and VOD? Quote
Ryu Posted January 2 Posted January 2 (edited) 4 minutes ago, Nahannz said: Successfully factory reset and rebooted. Where do I find server information for buzztv to gain back access to live TV and VOD? when it comes back to Home Screen then you will go to server settings to enter your provider info. Edited January 2 by Ryu Quote
nbs. Posted January 2 Posted January 2 4 minutes ago, Nahannz said: Successfully factory reset and rebooted. Where do I find server information for buzztv to gain back access to live TV and VOD? Contact your service Quote
iserna Posted January 2 Author Posted January 2 1 hour ago, Nahannz said: Did a new power supply work? I am experiencing the same issue with my U5 now. It loads the buzztv logo and gets stuck there. After several minutes it goes black. The hard reset has not been loading the restore menu. Yes. It worked. Quote
Nahannz Posted January 2 Posted January 2 2 hours ago, Ryu said: when it comes back to Home Screen then you will go to server settings to enter your provider info. 2 hours ago, nbs. said: Contact your service Thanks for your help! My box is back up and running! 4 Quote
