iserna Posted Saturday at 09:50 PM Posted Saturday at 09:50 PM Hello. I’ve had no problems with my U5 since I bought it. I went out for vacation and since returning, the U5 had a black screen. Unplugged and waited for 5 mins and when plugging it back, it loads the BuzzTV animated screen logo and then goes back to black. After about 4 minutes it restarts and does the same thing again. Any suggestions regarding what I should do? Thanks! Quote
Ryu Posted Saturday at 09:55 PM Posted Saturday at 09:55 PM not sure if the power supply was disconnected and if yes make sure using original power supply. also, try a different outlet if possible. try to disconnect all external devices like usb, or external drives and swap hdmi cable. if still nothing then factory reset using AV hole with tooth pick. 1 Quote
iserna Posted yesterday at 02:53 AM Author Posted yesterday at 02:53 AM 4 hours ago, Ryu said: not sure if the power supply was disconnected and if yes make sure using original power supply. also, try a different outlet if possible. try to disconnect all external devices like usb, or external drives and swap hdmi cable. if still nothing then factory reset using AV hole with tooth pick. Thank you. I did what you suggested. Checked the cable and it’s the original one. Changed HDMI cables and ports. Also used the toothpick on the back and got a message saying restart or power off. I selected restart and same thing happens. Any more help will be greatly appreciated. Thanks! Quote
nbs. Posted yesterday at 02:57 AM Posted yesterday at 02:57 AM If you are getting that message you are not doing the reset properly Follow this guide different model but same procedure 2 Quote
iserna Posted 23 hours ago Author Posted 23 hours ago I tried that. All I get is the BuzzTv fix logo (no animation). No restore menu. Am I doing something wrong? I unplugged the unit, used the toothpick, plugged the unit while keeping the toothpick pressing the button. Nothing happens. The led is red and after about 90 seconds turns blue. When it goes blue, the HDMI signal is lost. Thanks Quote
Mark7 Posted 21 hours ago Posted 21 hours ago I think your power supply may have failed. Try and get a new one, the unit is probably fine. Mark7 1 Quote
Ryu Posted 21 hours ago Posted 21 hours ago you did not get recovery screen? if possible try a different power supply to see if that helps and if its still under warranty I would contact buzztv support. 1 Quote
nbs. Posted 20 hours ago Posted 20 hours ago 3 hours ago, iserna said: I tried that. All I get is the BuzzTv fix logo (no animation). No restore menu. Am I doing something wrong? I unplugged the unit, used the toothpick, plugged the unit while keeping the toothpick pressing the button. Nothing happens. The led is red and after about 90 seconds turns blue. When it goes blue, the HDMI signal is lost. Thanks Can you feel the button being pressed? 3 Quote
dishuser Posted 19 hours ago Posted 19 hours ago 23 minutes ago, nbs. said: Can you feel the button being pressed? if it's quiet you can hear it 2 Quote
dishuser Posted 19 hours ago Posted 19 hours ago 25% off right now https://buzztvdirect.com/en-ca/collections/power-supplies/products/buzztv-12v-power-supply-ac-adapter-for-xrs4900 2 Quote
iserna Posted 12 hours ago Author Posted 12 hours ago 7 hours ago, nbs. said: Can you feel the button being pressed? Yes. It’s absolutely pressed 2 Quote
iserna Posted 12 hours ago Author Posted 12 hours ago 7 hours ago, dishuser said: 25% off right now https://buzztvdirect.com/en-ca/collections/power-supplies/products/buzztv-12v-power-supply-ac-adapter-for-xrs4900 Thanks. I ordered it. It will take a while for me to get it but I’ll let you know when I do. Thanks! 2 Quote
dishuser Posted 8 hours ago Posted 8 hours ago I just remembered a couple of years ago my buddy had this problem and it was a bad hdmi cable Quote
iserna Posted 8 hours ago Author Posted 8 hours ago 18 minutes ago, dishuser said: I just remembered a couple of years ago my buddy had this problem and it was a bad hdmi cable I thought so. I changed the cable to the one used in the AppleTV and the problem persists. Thanks 1 Quote
