bclark1000 Posted April 14 Posted April 14 Which one do you guys have? Which one are you happy with and which one are you not happy with? Quote
Ryu Posted April 14 Posted April 14 I don't recommended here other than buzztv hardware/software. however, something I like you may not like or something works for you may not work you. most of the vpn nowadays offer up to month with money back guarantee. I would say try and see how that works for you. Quote
jets Posted April 16 Posted April 16 I've been using Windscribe, works very well and has a nice big interface. Make sure to download windscribe-tv.apk it's the Android TV version. If you get the phone version you won't like the interface. They offer free of 10GB per month, but look at the paid version. I am not affiliated with them in anyway. 1 Quote
dishuser Posted April 16 Posted April 16 10gb isn't even one 4k vod so forget about the free version...lol Quote
Emporium Posted April 16 Posted April 16 23 minutes ago, dishuser said: 10gb isn't even one 4k vod so forget about the free version...lol But you typically don't need VPN for VOD. At least in my case, VOD and TV Series I have never needed to use VPN (with at least 3 different services - but could be different for others). And 10GB is plenty for a few hours of LiveTV, as a test to confirm if VPN will help your situation (assuming you have blackouts/throttling). The 10GB is NOT for permanent use, since you will run out if used for daily use. I've been using windscribe (amongst others) also and no issues either. I like their AndroidTV client. And you can get pretty good pricing (less than CDN$3/month) if you look through sites like stacksocial, and stacksocial often has additional discounts above the discounted price. Many other services like ipvanish also offer a decent product with reasonable pricing. Quote
jets Posted April 16 Posted April 16 I got three years unlimited for some ridiculousness low price. At your recommendation Emporium, I might add . 1 Quote
dishuser Posted April 16 Posted April 16 44 minutes ago, Emporium said: But you typically don't need VPN for VOD. At least in my case, VOD and TV Series I have never needed to use VPN (with at least 3 different services - but could be different for others). And 10GB is plenty for a few hours of LiveTV, as a test to confirm if VPN will help your situation (assuming you have blackouts/throttling). The 10GB is NOT for permanent use, since you will run out if used for daily use. I've been using windscribe (amongst others) also and no issues either. I like their AndroidTV client. And you can get pretty good pricing (less than CDN$3/month) if you look through sites like stacksocial, and stacksocial often has additional discounts above the discounted price. Many other services like ipvanish also offer a decent product with reasonable pricing. most people use a vpn so there's no trace as to what their activity is I know I do 3 Quote
Chris79 Posted April 28 Posted April 28 I've been using amnezia, up to now has been really good. Quote
