sperron Posted December 14, 2024 Posted December 14, 2024 Hi, No sound on my TV when I'm using the X5 Super Sport model that I recently bought on black Friday! If I plug my U5 (same cable, same TV and port)= working. Need help before contacting BuzzTV support. Any idea? Thanks Sylvain Quote
nbs. Posted December 14, 2024 Posted December 14, 2024 Try the cable that came with the SS anyway 2 Quote
Ryu Posted December 14, 2024 Posted December 14, 2024 also, validate sound settings on SS and post your sound settings info please. 1 Quote
sperron Posted December 15, 2024 Author Posted December 15, 2024 (edited) Hi, After soft reset (Thanks Peter), the stereo sound working but not the surround sound throught the hdmi. working on my U5 but not with the X5 ss (I'm using same port, same cables on my TV for the 2 devices) Disabling system sound = do nothing also changing parameters None or manual Thanks for your support Sylvain Edited December 15, 2024 by sperron Quote
sperron Posted December 30, 2024 Author Posted December 30, 2024 (edited) On 12/13/2024 at 9:55 PM, sperron said: Hi, No sound on my TV when I'm using the X5 Super Sport model that I recently bought on black Friday! If I plug my U5 (same cable, same TV and port)= working. Need help before contacting BuzzTV support. Any idea? Thanks Sylvain NEW UPDATE: After some tests, I have the stereo sound but not the surround sound on the IPTV channels using Buzz TV app. After installing a third app XCIPTV, stereo and surround sound = working. Question: Is new firmware update planned to solve this problem? Thanks Edited December 30, 2024 by sperron Quote
dishuser Posted December 30, 2024 Posted December 30, 2024 have you tried it with force max volume on? Quote
nbs. Posted December 30, 2024 Posted December 30, 2024 When you were on the other site you had users tell you to check your tv settings as they have no issues with their surround sound passing through 1 Quote
sperron Posted January 14 Author Posted January 14 On 12/29/2024 at 8:14 PM, dishuser said: have you tried it with force max volume on? Yes, didn't work Quote
sperron Posted January 14 Author Posted January 14 On 12/29/2024 at 8:37 PM, nbs. said: When you were on the other site you had users tell you to check your tv settings as they have no issues with their surround sound passing through No special settings for that on my TV. I used Buzz XPL 3000, an U5 and XRS 4900 on the same TV and the stereo and surround working throught the Buzz App. The only change is the unit for the X5 Super Sport model and since this model I have the sound problem. Thanks Quote
Emporium Posted January 14 Posted January 14 Have you tried the latest update that was just sent today (included X5 SS) https://stbtalk.com/topic/14395-new-buzz-5-app-update-version-946-jan-13th-2025/ 1 Quote
sperron Posted January 14 Author Posted January 14 8 hours ago, Emporium said: Have you tried the latest update that was just sent today (included X5 SS) https://stbtalk.com/topic/14395-new-buzz-5-app-update-version-946-jan-13th-2025/ No, the problem still there. In the BuzzTV OTA screen firmware = v20240930. In the BuzzTV app, firmware = 5.0.946 01/03/2025 Quote
sperron Posted January 17 Author Posted January 17 On 1/14/2025 at 7:02 AM, sperron said: No, the problem still there. In the BuzzTV OTA screen firmware = v20240930. In the BuzzTV app, firmware = 5.0.946 01/03/2025 Yes x5 is up-to-date and the problem is still there Quote
