Dave J Posted November 26, 2024 Posted November 26, 2024 I had to boot to recovery on my Classic (fw 20240927, BuzzTV 5.0.940), and the screen is split in half (aspect is way off). Thought I read about this somewhere but I can't find any info. Can anyone offer any suggestions? Quote
Ryu Posted November 26, 2024 Posted November 26, 2024 not sure if I read correct use tv remote control to adjust picture size and then use recovery options to do whatever you want to do. Quote
Dave J Posted November 26, 2024 Author Posted November 26, 2024 A soft reset will wipe the box to factory condition, but it doesn't involve the Android recovery like a hard reset would. That's where I found this problem. I haven't tried changing the aspect ratio / screen size in the BuzzTV app, as I would assume that the Android recovery screen video output would be different from the app. Never experienced this on my 4500's, so I'm curious why this has happened. Quote
Emporium Posted November 27, 2024 Posted November 27, 2024 Do a soft reset first like nbs suggested and then you can do a hard reset if you want I've hard reset it many times, and never had an issue. But then again, my classic is connected to a computer monitor. Quote
Dave J Posted December 16, 2024 Author Posted December 16, 2024 Forgot to update this, Ryu was correct in that you need to adjust the resolution down on the box before doing a hard reset in order for the recovery screen size to be correct. This is different from my old 4500's on Android 9, but no big deal. Thanks everyone. 1 Quote
nbs. Posted December 17, 2024 Posted December 17, 2024 I've done a hard reset many times without adjusting resolution. Most times users don't have access to settings before doing hard reset 3 Quote
dishuser Posted December 17, 2024 Posted December 17, 2024 7 minutes ago, nbs. said: I've done a hard reset many times without adjusting resolution. Most times users don't have access to settings before doing hard reset when I reset mine recovery screen was smaller but was manageable once it rebooted it was fine since default resolution is auto 3 Quote
Gord Robina Posted Monday at 08:43 PM Posted Monday at 08:43 PM Hello Guys How do I hard reset my Buzz classic? Thanks Gord Robins Quote
dishuser Posted Monday at 09:04 PM Posted Monday at 09:04 PM unplug the power push the button on the box and hold down hook up power release button when recovery screen appears select wipe data/factory reset Quote
Gord Robina Posted Monday at 09:08 PM Posted Monday at 09:08 PM Are You refering to the power button on the side of the box Thanks Quote
dishuser Posted Monday at 09:22 PM Posted Monday at 09:22 PM 14 minutes ago, Gord Robina said: Are You refering to the power button on the side of the box Thanks there's only one button on the box 1 1 Quote
dishuser Posted Monday at 09:44 PM Posted Monday at 09:44 PM 8 minutes ago, Gord Robina said: Nothing happening??? are you holding the button when applying power? Quote
Gord Robina Posted Monday at 09:58 PM Posted Monday at 09:58 PM Yes, comes up Buzz tv then screen goes blank then nothing, blue light is on, how long should it take? Quote
Gord Robina Posted Monday at 10:43 PM Posted Monday at 10:43 PM No joy, will try later Thanks Gord Quote
Gord Robina Posted Monday at 11:03 PM Posted Monday at 11:03 PM 1 hour ago, dishuser said: about 10 seconds Well gotter done, need to use computer monitor. Thanks for your info Gord 1 Quote
dishuser Posted Monday at 11:14 PM Posted Monday at 11:14 PM you could have changed resolution on tv as well 1 Quote
