Mark7 Posted September 15, 2024 Author Posted September 15, 2024 Yes, I will be at Buzz HQ next week. Love the P6, but understand programming issues. Thanks everyone for you help. Still have 2 Killer XRS4900 MAX as back up. And a U5 Quote
Ryu Posted September 15, 2024 Posted September 15, 2024 1 minute ago, Mark7 said: Yes, I will be at Buzz HQ next week. Love the P6, but understand programming issues. Thanks everyone for you help. Still have 2 Killer XRS4900 MAX as back up. And a U5 https://www.youtube.com/@BuzzTVGlobal you can also check their channel. they have lots of great videos and info about their products. Quote
razor07 Posted September 15, 2024 Posted September 15, 2024 Ok seems to be working, will try others that would not load, why is plug-in on new server blue not white? Quote
razor07 Posted September 15, 2024 Posted September 15, 2024 Ok seems to be working, why is plug-in top right corner of new server window blue not white? Quote
Ryu Posted September 15, 2024 Posted September 15, 2024 2 minutes ago, razor07 said: Ok seems to be working, why is plug-in top right corner of new server window blue not white? good to hear that. I dont know as I dont have this unit hopefully someone with this until will be able to answer you. 1 Quote
Mark7 Posted September 15, 2024 Author Posted September 15, 2024 Hi razor07 can you show us a picture or a screen shot? Quote
pugsycan Posted September 15, 2024 Posted September 15, 2024 53 minutes ago, razor07 said: Ok seems to be working, why is plug-in top right corner of new server window blue not white? Well if I think I know what you mean The blue means the one you are connected to I have 2 servers on XC and the one connected is blue and the other is white 2 1 Quote
Ryu Posted September 15, 2024 Posted September 15, 2024 2 minutes ago, pugsycan said: Well if I think I know what you mean The blue means the one you are connected to I have 2 servers on XC and the one connected is blue and the other is white thank you sir. 1 Quote
razor07 Posted September 16, 2024 Posted September 16, 2024 I just loaded another xc server, which will make 3, when there were 2, 1 white, 1 blue, so I switched to white 1 blue turned red. Now 2 white, 1 blue which I was one, switched server, the 1 I was turned red, I am starting to understand, the main thing is the problem was solved thanks to all. 1 Quote
Ryu Posted September 16, 2024 Posted September 16, 2024 1 minute ago, razor07 said: I just loaded another xc server, which will make 3, when there were 2, 1 white, 1 blue, so I switched to white 1 blue turned red. Now 2 white, 1 blue which I was one, switched server, the 1 I was turned red, I am starting to understand, the main thing is the problem was solved thanks to all. thats how we learn. good stuff 1 Quote
whacked Posted September 16, 2024 Posted September 16, 2024 you can also see which server portal is connected while viewing LiveTV. While on a channel, press the Down key pad on the RCU and the server name will appear there in that bottom info bar. in the past, naming a server was not so much important, but now naming the server portal with a descriptive name comes into play 4 Quote
Ryu Posted September 16, 2024 Posted September 16, 2024 10 hours ago, whacked said: you can also see which server portal is connected while viewing LiveTV. While on a channel, press the Down key pad on the RCU and the server name will appear there in that bottom info bar. in the past, naming a server was not so much important, but now naming the server portal with a descriptive name comes into play thank you thats actually pretty cool. 1 Quote
razor07 Posted September 17, 2024 Posted September 17, 2024 (edited) This is what I am getting on 1 server that was good before? Edited September 17, 2024 by allaboutbuzz Shouldn't post photos of servers Quote
razor07 Posted September 17, 2024 Posted September 17, 2024 All was good yesterday, even did a recording, which was fine. Now I am back to square 1 with channel stream errors on 2 servers and 1 has no guide. Cleaned cache, unplugged same? Quote
nbs. Posted September 17, 2024 Posted September 17, 2024 You should not post pics of iptv servers Quote
nbs. Posted September 17, 2024 Posted September 17, 2024 Did you message allaboutbuzz with your info the other day when I suggested it? 2 1 Quote
razor07 Posted September 17, 2024 Posted September 17, 2024 Sorry about that did not even think that would be a problem, will not happen again. 1 Quote
Mark7 Posted September 18, 2024 Author Posted September 18, 2024 Sorry, I did not think that would be a problem. Quote
Mark7 Posted September 18, 2024 Author Posted September 18, 2024 1 hour ago, nbs. said: Did you message allaboutbuzz with your info the other day when I suggested it? Yes, there is a fix in the works. Thank you for your help. Mark7 Quote
