razor07 Posted August 31, 2024 Posted August 31, 2024 Hi, does anyone have audio issues after newest update yesterday? Quote
Emporium Posted August 31, 2024 Posted August 31, 2024 Would be nice if you explain what type of audio issues. And what type of setup. Some people have more complex setups with soundbars, receivers, audio processors/decoders, etc.. I did not notice any issue on my setup at least. 2 Quote
razor07 Posted August 31, 2024 Author Posted August 31, 2024 Sorry, just standard Panasonic tv no audio on recordings and stremio app no audio, check on other device and all works. Quote
nbs. Posted August 31, 2024 Posted August 31, 2024 51 minutes ago, razor07 said: Sorry, just standard Panasonic tv no audio on recordings and stremio app no audio, check on other device and all works. Recordings you have done with buzz 6? Quote
razor07 Posted August 31, 2024 Author Posted August 31, 2024 I uninstalled Stremio and re-installed hoping the audio problem would be fixed, but no, so must be from the new update? 1 Quote
Emporium Posted August 31, 2024 Posted August 31, 2024 Try going into settings (from home screen), sound, and switch to the option that says "do not decode surround sound" or something like that (not at home right now). Quote
razor07 Posted August 31, 2024 Author Posted August 31, 2024 just tried all settings in advanced settings no luck, thanks Quote
Emporium Posted August 31, 2024 Posted August 31, 2024 Does audio work with the other built in apps, like youtube and PlutoTv ? Quote
Ryu Posted August 31, 2024 Posted August 31, 2024 Just curious, are you using the HDMI cable that came with it? Also, try reseating the HDMI cable, and if possible, try a different HDMI port or cable. Quote
Tony 62 Posted August 31, 2024 Posted August 31, 2024 (edited) Same happened to me , lost all my audio . How I fixed it for now instead of doing a factory reset. Opened the BT remote app and toggled the MAX VOLUME switch. Resorted the audio but I have to use the receiver hand set to control the volume . All apps were the same Zero audio .. Edited August 31, 2024 by Tony 62 1 Quote
razor07 Posted August 31, 2024 Author Posted August 31, 2024 Just tried all of the above, no audio. Quote
Tony 62 Posted September 1, 2024 Posted September 1, 2024 4 hours ago, razor07 said: Just tried all of the above, no audio. Probably going to have to do a reset ... I've already done one. Quote
Ryu Posted September 1, 2024 Posted September 1, 2024 1 hour ago, Tony 62 said: Probably going to have to do a reset ... I've already done one. give a one more try please. also try on another tv and see if you get an audio. Quote
sts41 Posted September 1, 2024 Posted September 1, 2024 I had the same issue after the update, I used the BT500, went into "Home", "Utilities", "Volume Control" and turned off "Force Max Volume". I then used the volume control on the remote to raise the volume of the P6 to Max... then turned back on "Forced Max Volume" This worked for me, and I hope it helps you.... 1 Quote
razor07 Posted September 1, 2024 Author Posted September 1, 2024 I tried another TV and HDMI cable, will wait for next update before reset as I have other errors to be corrected, thanks for all the suggestions. 2 Quote
