Ryu Posted August 14, 2024 Posted August 14, 2024 (edited) 39 minutes ago, sts41 said: Funny, mine is the opposite, I can get connected to Buzztv 6 but BuzzTV 5 gives error that incorrect username and password. I am using MAC with no need for User or Pass. I am able to connect to Buzz5 on my older 4500 box. With all the bugs, I would really like to be able to connect to Buzz 5 for the next month or so. Unfortunatly, I sold the 4500 and it is now gone... I think that was premature.  just curios did you perform a rest on provider side before switching back to buzz5? If not then try that first. Edited August 14, 2024 by Ryu Quote
sts41 Posted August 14, 2024 Author Posted August 14, 2024 7 minutes ago, Ryu said: just curios did you perform a rest on provider side before switching back to buzz5? If not then try that first. No, I did not go back to provider since It worked on P6 and my old Buzz 5.... Am I assuming correct that rest = reset? I will explain the situation to them, maybe they can also come up with a way I can jump back and forth. Quote
sts41 Posted August 14, 2024 Author Posted August 14, 2024 19 minutes ago, dishuser said: are you accessing catchup from bottom toolbar(options)? No.... just EPG, lookup show and press enter. I will try and see if that works Quote
sts41 Posted August 14, 2024 Author Posted August 14, 2024 13 minutes ago, sts41 said: No.... just EPG, lookup show and press enter. I will try and see if that works It worked, This is great... I am mostly back up and running, or at least crawling  but that was a big step. Quote
Terry mah Posted August 14, 2024 Posted August 14, 2024 Just got my P6 but cant seem to pair remote anyone else with this problem Quote
Terry mah Posted August 14, 2024 Posted August 14, 2024 Ok thanks.did yours pair automatic or did you hold ok and home button Quote
Corey Skipper Posted August 14, 2024 Posted August 14, 2024 15 hours ago, Ryu said: are you on same network? Yes same network. I tried 4 different devices. 1 Quote
nbs. Posted August 14, 2024 Posted August 14, 2024 30 minutes ago, Terry mah said: Ok thanks.did yours pair automatic or did you hold ok and home button Held buttons Quote
allaboutbuzz Posted August 14, 2024 Posted August 14, 2024 54 minutes ago, Terry mah said: Still cant get mine to pair On the BT 500 you can try factory resetting the remote first By holding down the  0+down button for 5 seconds. It should blink 3x to confirm its been reset  Then you can long press the info button while pointing the remote at the box to bring up the pairing animation. 3 Quote
Terry mah Posted August 14, 2024 Posted August 14, 2024 My P6 is stuck here never got any further from first turning it on Quote
allaboutbuzz Posted August 14, 2024 Posted August 14, 2024 7 minutes ago, Terry mah said: Which is info button please The i button in between Ch +/- and Vol +/- Quote
allaboutbuzz Posted August 14, 2024 Posted August 14, 2024 1 minute ago, Terry mah said: My P6 is stuck here never got any further from first turning it on So pairing the remote here doesn't work at all? You can also press the back button to exit this and just use the remote as IR for now to go through the welcome screen Quote
Terry mah Posted August 14, 2024 Posted August 14, 2024 Tried back button didn't work seems to be stuck on the pairing screen  Quote
Terry mah Posted August 14, 2024 Posted August 14, 2024 I did back button asked if I wanted to cancel Bluetooth pairing I clicked yes and now just back to black screen  Quote
freeloader Posted August 14, 2024 Posted August 14, 2024 I had problems pairing mine also had to shut off box 3 time then it worked. 2 Quote
sea157 Posted August 14, 2024 Posted August 14, 2024 Try unplugging the box from electric for about 30 seconds, the plug it back in and let it reboot. This always seems to help me when I have problems like that. Quote
freeloader Posted August 14, 2024 Posted August 14, 2024 I noticed in live tv with P6 that there are a whole row of options missing, change player etc. P5 works fine all options are there. i have the latest update 809. no problem works great very fast response. Quote
allaboutbuzz Posted August 14, 2024 Posted August 14, 2024 6 minutes ago, freeloader said: I noticed in live tv with P6 that there are a whole row of options missing, change player etc. P5 works fine all options are there. i have the latest update 809. no problem works great very fast response. Yes we will be adding all of the Configuration options in future updates to Buzz 6 1 1 Quote
Terry mah Posted August 14, 2024 Posted August 14, 2024 How do you get keyboard up on remote I've managed to get past the remote pairing part Quote
Terry mah Posted August 14, 2024 Posted August 14, 2024 All sorted now thank you all for the help  Quote
allaboutbuzz Posted August 14, 2024 Posted August 14, 2024 25 minutes ago, Terry mah said: All sorted now thank you all for the help  How did you sort it? Quote
