sts41 Posted August 12, 2024 Posted August 12, 2024 I thought it would be great to have a place to report Bugs and if someone has a workaround, post that also. I will repost the Bugs I mentioned in another post, and the workarounds I was told, or found. If you find another Bug, please add it to this post and hopefully they will get addressed. 1 Quote
sts41 Posted August 12, 2024 Author Posted August 12, 2024 The EPG guide does not come up when remote "Guide" button is pressed. Workaround: Select Menu, and then EPG.  When creating a PVR entry, if you Press OK on the Start or Stop time, you can edit the Hours, but cannot highlight Minutes, or adjust. Workaround: (From Emporium) when you get the popup for the recording details, you can change the minutes if you press left/right on the DPAD when you are on either date/time of start or end. But, if you press OK (for example on Start time) to go into the next popup to choose, then you select the time, then NO, you can change the hour, but no way to go right to change the minutes.  Quote
sts41 Posted August 12, 2024 Author Posted August 12, 2024 When in EPG, Red button does not bring up Categories Workaround:Â From any live channel, Press OK to bring up Detailed Channel EPG, then press Left Dpad to enter Categories. Quote
sts41 Posted August 13, 2024 Author Posted August 13, 2024 (edited) in timeshift, when you use the FF and RV, there apears to be some menus's below the screen that cannot be seen. Workaround:  None Edited August 13, 2024 by sts41 Quote
dishuser Posted August 13, 2024 Posted August 13, 2024 10 hours ago, sts41 said: in timeshift, when you use the FF and RV, there apears to be some menus's below the screen that cannot be seen. Workaround:  None did you press the down arrow? Quote
sts41 Posted August 13, 2024 Author Posted August 13, 2024 56 minutes ago, dishuser said: did you press the down arrow? Thank you..... That was it. Had to press down a few times through various selections, but then it did come up. Quote
allaboutbuzz Posted August 13, 2024 Posted August 13, 2024 Guide button will be fixed on our next OTA coming this week We will fix the Red Button to open Categories in Grid Guide as well, just not sure if it will make it into the next OTA Will look into the PVR time issue. 1 Quote
sts41 Posted August 13, 2024 Author Posted August 13, 2024 Watching shows in the past is not working. Tested on my XRS4500 with same stream and it is working there. Quote
sts41 Posted August 13, 2024 Author Posted August 13, 2024 2 hours ago, allaboutbuzz said: Guide button will be fixed on our next OTA coming this week We will fix the Red Button to open Categories in Grid Guide as well, just not sure if it will make it into the next OTA Will look into the PVR time issue. thank you for the update 1 Quote
dishuser Posted August 13, 2024 Posted August 13, 2024 2 hours ago, sts41 said: Watching shows in the past is not working. Tested on my XRS4500 with same stream and it is working there. if you mean catchup it worx 2 Quote
Corey Skipper Posted August 13, 2024 Posted August 13, 2024 add server by qr code does not work. It says route not found Its says route not found on the screen unless im doing something wrong. Quote
Ryu Posted August 13, 2024 Posted August 13, 2024 1 hour ago, Corey Skipper said: add server by qr code does not work. It says route not found Its says route not found on the screen unless im doing something wrong. are you on same network? Quote
dishuser Posted August 14, 2024 Posted August 14, 2024 20 minutes ago, Chris1 said: I am having the same issue did you pm aab? your login worx with buzztv 5 but not buzztv 6 1 Quote
dishuser Posted August 14, 2024 Posted August 14, 2024 9 minutes ago, Chris1 said: Yes and I forgot to massage him I'm sure at the end of the day he would appreciate a massage but you need to message him first 1 2 Quote
nbs. Posted August 14, 2024 Posted August 14, 2024 (edited) You were asked if you had / at end of url Urls with /c won't work on buzz 6 on xc Edited August 14, 2024 by nbs. Quote
dishuser Posted August 14, 2024 Posted August 14, 2024 27 minutes ago, nbs. said: You were asked if you had / at end of url Urls with /c won't work on buzz 6 on xc I tested their account last night and it only worx on buzztv 5 on the power station no / at the end of portal url Quote
dishuser Posted August 14, 2024 Posted August 14, 2024 34 minutes ago, Chris1 said: You are talking about allaboutbuzz allaboutbuzz is correct 1 Quote
sts41 Posted August 14, 2024 Author Posted August 14, 2024 12 hours ago, dishuser said: did you pm aab? your login worx with buzztv 5 but not buzztv 6 Funny, mine is the opposite, I can get connected to Buzztv 6 but BuzzTV 5 gives error that incorrect username and password. I am using MAC with no need for User or Pass. I am able to connect to Buzz5 on my older 4500 box. With all the bugs, I would really like to be able to connect to Buzz 5 for the next month or so. Unfortunatly, I sold the 4500 and it is now gone... I think that was premature. Â Quote
sts41 Posted August 14, 2024 Author Posted August 14, 2024 15 hours ago, dishuser said: if you mean catchup it worx No, the ability to select a show in the last couple of days, (Normally just a couple of hours), and stream that. This worked very well on my 4500, and the P6 shows that the channel is recognized as one that can go back in the past, but get error that Stream is unavailable. That exact same show will work fine on 4500. Quote
dishuser Posted August 14, 2024 Posted August 14, 2024 5 minutes ago, sts41 said: No, the ability to select a show in the last couple of days, (Normally just a couple of hours), and stream that. This worked very well on my 4500, and the P6 shows that the channel is recognized as one that can go back in the past, but get error that Stream is unavailable. That exact same show will work fine on 4500. that's catchup Quote
sts41 Posted August 14, 2024 Author Posted August 14, 2024 6 minutes ago, dishuser said: that's catchup Do you know if there are any settings related to catchup? Maybe I turned something off. I would hate to hard factory reset without the backup/restore config functionality... But I may do it anyway this evening. Quote
dishuser Posted August 14, 2024 Posted August 14, 2024 (edited) are you accessing catchup from bottom toolbar(options)? Edited August 14, 2024 by dishuser Quote
