Emporium Posted March 16 Posted March 16 3 minutes ago, dishuser said: when watching it info brings that up I understood that they wanted to see this info from the VOD/TV Series selection screen before they watch it. When watching, then obviously it is available I may have misunderstood. 1 Quote
dishuser Posted March 16 Posted March 16 31 minutes ago, Emporium said: I understood that they wanted to see this info from the VOD/TV Series selection screen before they watch it. When watching, then obviously it is available I may have misunderstood. I've never seen that before playing going all the way back to buzztv 2 1 Quote
Emporium Posted March 16 Posted March 16 1 hour ago, dishuser said: I've never seen that before playing going all the way back to buzztv 2 This is a WISHLIST after all. Does not mean they are wishes that will be granted 2 Quote
Emporium Posted March 18 Posted March 18 When you are in categories and go to "organize categories", it would be nice to use the CH+/CH- buttons to scroll through the categories quicker (like you can in Channel list and EPG view) 2 Quote
Chris79 Posted March 19 Posted March 19 I'd like to be able to change channel names and manually sort channel orders. Quote
dishuser Posted March 19 Posted March 19 5 hours ago, Chris79 said: I'd like to be able to change channel names and manually sort channel orders. use m3u Quote
Elie Posted March 19 Posted March 19 Hello it is possible to to make the keyboard when you type to go from right to left straight from one side to the other with out going back formuler box has thay option in the keyboard thanks 1 Quote
Pittro Posted April 7 Posted April 7 i dont know if this was mentioned but would be nice to have a channel history when searching channels instead of just the 1 go back & forth button..someting similar that Tivi mate uses when selecting ok button..i always like where you have a selection of at least 5 channels that ive been too Quote
Emporium Posted April 7 Posted April 7 15 minutes ago, Pittro said: i dont know if this was mentioned but would be nice to have a channel history when searching channels instead of just the 1 go back & forth button..someting similar that Tivi mate uses when selecting ok button..i always like where you have a selection of at least 5 channels that ive been too As mentioned. That option has been on buzz boxes for ages. Long Press the "back/last ch" button and it should bring up a list. On BuzzTV 5, I think it was 20 last stations.. On the Powerstation (BuzzTV 6), it looks like it is a LOT longer than that (I have about 50 of them in my list) Very handy when switching between 3 or more channels. 2 Quote
smiley2069 Posted April 8 Posted April 8 Be able to do cloud storages on your network that all your Buzz TV PowerStation can play and record too. And to be able to back up your total buzz Tv box with all the apps and passwords you Smiley Quote
Mikisiw Posted April 22 Posted April 22 I would like to see a better Mute button position on the BT-500. Perhaps an option to add "mute" to the colored button mapping. 2 1 Quote
Emporium Posted April 22 Posted April 22 The colored buttons are only "user" mapped when you are outside of the buzztv app and primarily on the home screen. When you are in buzztv app, the colored buttons are controlled by the app, and the legend is always on the bottom depending on what screen/function you are on. But if you don't like the layout of the BT500, you can always pick up another buzz remote (BT200, BT250, BT350, etc..). Or instead of using the mute button, just press and hold the volume down button, takes less than a second to go from 100 to 0. That's what I do, since I am always using the buttons around the Dpad. 2 Quote
Ryu Posted April 22 Posted April 22 9 hours ago, Mikisiw said: I would like to see a better Mute button position on the BT-500. Perhaps an option to add "mute" to the colored button mapping. ask them to invite you next time they design a new remote control. 1 1 Quote
Mikisiw Posted April 27 Posted April 27 (edited) I don't use the BuzzTV app. Just Tivimate and the added option to map one of the coloured buttons for mute would be very helpful. Edited April 27 by Mikisiw Quote
dishuser Posted April 27 Posted April 27 7 minutes ago, Mikisiw said: I don't use the BuzzTV app. Just Tivimate and the added option to map one of the coloured buttons for mute would be very helpful. you expect support for a 3rd party app? 1 1 Quote
Mikisiw Posted April 27 Posted April 27 (edited) 2 minutes ago, dishuser said: you expect support for a 3rd party app? Didn't say that. But do you honestly think I only use this box specifically for Buzz apps? Edited April 27 by Mikisiw 1 Quote
Emporium Posted April 27 Posted April 27 (edited) 10 minutes ago, Mikisiw said: I don't use the BuzzTV app. Just Tivimate and the added option to map one of the coloured buttons for mute would be very helpful. Then ask the dev of Tivimate to allow you to map a key to mute in their app. Title of thread is: "BuzzTV6 Application: Wishlist for New Features and Enhancements" 3rd party apps can do as they wish, but they are not supported by Buzz. You request has NOTHING to do with BuzzTV 6. Edited April 27 by Emporium 2 Quote
Emporium Posted April 27 Posted April 27 1 minute ago, Mikisiw said: Didn't say that. But do you honestly think I use this box specifically for Buzz apps? If you don't, then you are obviously in the wrong forum. Quote
Mikisiw Posted April 27 Posted April 27 (edited) 5 minutes ago, Emporium said: If you don't, then you are obviously in the wrong forum. Now that is amusing and naive. I think it said wish list. But thanks for your input. Going to let this go now as I certainly don't want to hijack a thread for an inane arguement. Have a buffer free evening. Edited April 27 by Mikisiw Quote
Emporium Posted April 27 Posted April 27 4 minutes ago, Mikisiw said: Now that is amusing and naive. I think it said wish list. But thanks for your input. Going to let this go now as I certainly don't want to hijack a thread for an inane arguement. Haveabudferfreeevenong. There is NOTHING naïve about it... This is the the "BUZZTV 6 Application" wish list. You are not using the BuzzTV 6 application, since you clearly said you are using Tivimate, your request makes no sense. The colored buttons are mapped at the HOME screen for whatever user wants to program them to launch, and then once in an app, the APP can map them, just like the archaic STBEMU allows you to map every damn key on the remote to an action. If the dev of Tivimate does not want to do that, that is their choice. They are the ones who can do that in their app. 3 Quote
ManFromRI Posted July 20 Posted July 20 Hi guys, I would like to request a feature/setting to allow for more than one EPG to be added to a Server. For example : let's say the server I'm using has incomplete or missing EPG data on the default EPG, It would be great to add a "universal" type EPG which can cover more info properly. I use 2 or 3 different EPG's on one server, due to different networks/countries, and it works pretty well, I just have to adjust the epg offsets to my time. And also, is there a way to change/adjust the server & epg update times?? Example : update on start, every 2, 4, 8, 12...etc Thanks. Quote
buzywoman Posted September 7 Posted September 7 ScreenShot Function, buzztv xrs-4900 and xrs-4500 have this function by long press to power button, PowerStation 6 not have this function. This is very important function. Please add this function, work with mini usb keyboard but not for all apps. tanks Quote
