dishuser Posted August 20, 2024 Posted August 20, 2024 16 minutes ago, allaboutbuzz said: Just tried the back button on every menu on Buzz 6 It works no problem. they said buzztv 5 Quote
Jeffrags Posted August 20, 2024 Posted August 20, 2024 10 hours ago, dishuser said: it's called cec which doesn't work Quote
dishuser Posted August 20, 2024 Posted August 20, 2024 10 minutes ago, Jeffrags said: which doesn't work does on mine 1 Quote
kyzursozay2 Posted August 21, 2024 Posted August 21, 2024 Buzz 6 with my provider is still having issues (live channels now have strange repeating instead of streaming error messages) so I am using Buzz 5 until fixed. Just pointing out differences I thought could work on 5 without going back to my 4900 Quote
dishuser Posted August 21, 2024 Posted August 21, 2024 I press the red power button and both box and tv turn on/off green power button for soundbar 1 Quote
pugsycan Posted August 21, 2024 Posted August 21, 2024 43 minutes ago, Jeffrags said: which doesn't work 32 minutes ago, dishuser said: does on mine Does on mine too 1 Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 12 hours ago, pugsycan said: Does on mine too done a hard reset and i can't get the latest update, and it shows what is in the pics, second topic is if I go and change the launcher. I was told I have the buxzzv5 firmware now not the buzztv6 firmware Quote
nbs. Posted August 21, 2024 Posted August 21, 2024 23 minutes ago, Jeffrags said: done a hard reset and i can't get the latest update, and it shows what is in the pics, second topic is if I go and change the launcher. I was told I have the buxzzv5 firmware now not the buzztv6 firmware Quote
nbs. Posted August 21, 2024 Posted August 21, 2024 There is only one firmware for the p6 You are posting the buzz 5 software As you've been told you need to be in the buzz 6 software and check menu 2 Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 33 minutes ago, nbs. said: There is only one firmware for the p6 You are posting the buzz 5 software As you've been told you need to be in the buzz 6 software and check menu how do i get the buzz 6 software? after the hard reset this is what I was left with Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 34 minutes ago, dishuser said: don't change the launcher i did this only playing around to see what the other launchers looked like but again, after the hard reset I guess I am left with bnuzz5 software and not buzz6 software and have no idea how to get buzz6 back Quote
dishuser Posted August 21, 2024 Posted August 21, 2024 3 minutes ago, Jeffrags said: i did this only playing around to see what the other launchers looked like but again, after the hard reset I guess I am left with bnuzz5 software and not buzz6 software and have no idea how to get buzz6 back home screen and hilite/select buzztv 6 Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 3 minutes ago, dishuser said: home screen and hilite/select buzztv 6 that just brings me to my iptv service that I added. it doesn't upgrade me to buzztv6 firmware Quote
Darrell Battle Posted August 21, 2024 Posted August 21, 2024 I would like the Bluetooth to be fixed. I was able to connect my Sony headphones, but the sound still comes through TV speakers or Audio system. Never through Bluetooth connection. Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 16 minutes ago, dishuser said: home screen and hilite/select buzztv 6 did another reset and this is the error at the bottom of the screen Quote
nbs. Posted August 21, 2024 Posted August 21, 2024 53 minutes ago, Jeffrags said: that just brings me to my iptv service that I added. it doesn't upgrade me to buzztv6 firmware No one said it would upgrade but you can hit the menu button and check bottom of pop up screen Again its not firmware it's software 1 Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 7 minutes ago, nbs. said: No one said it would upgrade but you can hit the menu button and check bottom of pop up screen Again its not firmware it's software on the update page this is what I see Quote
nbs. Posted August 21, 2024 Posted August 21, 2024 12 minutes ago, Jeffrags said: on the update page this is what I see Again that is not the software update page Quote
Emporium Posted August 21, 2024 Posted August 21, 2024 23 minutes ago, Jeffrags said: on the update page this is what I see And this is NORMAL. "V20240816" is the latest "firmware". 5.0.915 is the version of BuzzTV 5 installed. And that is fine, since BOTH buzztv5 and Buztv6 "software" are installed. For Home screen, you seem to have changed to the "BuzzTV Media Player 2" Home screen. To Launch BuzzTV 6 on that one (assuming you have not created a shortcut), you will need to select "ALL APPS" and you will see BuzzTV 6 on the second row, right next to BuzzTV 5. But BuzzTV 6 is a little different, when you select it, it will take you to the BuzzTV 6 home screen. Do youself a favor and just switch to the Buzztv 6 home screen to BuzzTV 6. So in summary.. V20240816 (as of today) is the latest firmware for the P6. BOTH buzzTV 5 and 6 software are installed on the P6. As of today. BuzzTV 5 version is 5.0.915 that is installed on this box. BuzzTV 6 version can vary (not going to go into details), either 1.0.16 or 1.0.17. To get updates to BuzzTV 6 (just like BuzzTV 5) software, you can go into menu->settings and select "check update". You can see the version that is installed on your device, when you hit the menu button, on the bottom left. If you see 1.0.xx then you are in buzztv 6, if you see 5.0.xxx you are in buzztv 5. 1 Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 1 hour ago, nbs. said: Again that is not the software update page where is it then? becasue homepage/buzztv6 def dosnet take me there it takes me to set up iptv Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 46 minutes ago, Emporium said: And this is NORMAL. "V20240816" is the latest "firmware". 5.0.915 is the version of BuzzTV 5 installed. And that is fine, since BOTH buzztv5 and Buztv6 "software" are installed. For Home screen, you seem to have changed to the "BuzzTV Media Player 2" Home screen. To Launch BuzzTV 6 on that one (assuming you have not created a shortcut), you will need to select "ALL APPS" and you will see BuzzTV 6 on the second row, right next to BuzzTV 5. But BuzzTV 6 is a little different, when you select it, it will take you to the BuzzTV 6 home screen. Do youself a favor and just switch to the Buzztv 6 home screen to BuzzTV 6. So in summary.. V20240816 (as of today) is the latest firmware for the P6. BOTH buzzTV 5 and 6 software are installed on the P6. As of today. BuzzTV 5 version is 5.0.915 that is installed on this box. BuzzTV 6 version can vary (not going to go into details), either 1.0.16 or 1.0.17. To get updates to BuzzTV 6 (just like BuzzTV 5) software, you can go into menu->settings and select "check update". You can see the version that is installed on your device, when you hit the menu button, on the bottom left. If you see 1.0.xx then you are in buzztv 6, if you see 5.0.xxx you are in buzztv 5. right i understand this but what i showed u in the pic is what I get when I CHECK FOR UPDATES.....buzztv6 seems to have been wiped from the device as all this shows is the info in that pic for buzztv5 Quote
allaboutbuzz Posted August 21, 2024 Posted August 21, 2024 5 minutes ago, Jeffrags said: where is it then? becasue homepage/buzztv6 def dosnet take me there it takes me to set up iptv The instructions was listed here in our announcement of the update You will be prompted for the update automatically. Or you can check manually when in Live TV, pressing Menu>Settings>Check Update 1 Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 13 minutes ago, allaboutbuzz said: The instructions was listed here in our announcement of the update You will be prompted for the update automatically. Or you can check manually when in Live TV, pressing Menu>Settings>Check Update when i go tt CHECK UPDATES i am shown that screen in the pic that shows buzztv5 software Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 i appreciate you alls help here but i think the box is fooked. lol Quote
