allinghj Posted June 23, 2024 Posted June 23, 2024 There's one channel that I watch a lot so when I'm done watching, I just leave my Classic on that channel. When I come back later in the day or maybe the next day, the channel is always switched to UK BBC4. What's going on here and how do I stop it? 1 Quote
Ryu Posted June 23, 2024 Posted June 23, 2024 (edited) more information is always better. do you power off your box or leave it on? what's your power off setting? is that Mac or XC API? how do you turn back on your device? do you press any button other than power? Edited June 23, 2024 by Ryu 1 Quote
Emporium Posted June 23, 2024 Posted June 23, 2024 Just curious, is the UK category one of the first categories in your providers natural lineup ? Reason I ask, is that I have one friend who swear that his box, every time he turns it on, it goes to the 4th channel (yes channel #4 without any renumbering active)) in the first category (which in his case is a 24/7 channel). Funny part, I use the same service and it has happened to me 2 or 3 times (same channel), but originally I ignored it, as a fluke, that maybe I had accidently hit some button before powering down.   1 Quote
pugsycan Posted June 23, 2024 Posted June 23, 2024 I am using the BT-400 remote And on one of my units when I turn off the tv it transmits a 8 the the stb (same frequency as the off signal as the tv's off) Just saying may be it I hit last channel and it takes me back to my regular channel  2 Quote
allinghj Posted June 23, 2024 Author Posted June 23, 2024 2 hours ago, Ryu said: more information is always better. do you power off your box or leave it on? what's your power off setting? is that Mac or XC API? how do you turn back on your device? do you press any button other than power? Â leave my stb on. I'm on XC API. Quote
allinghj Posted June 23, 2024 Author Posted June 23, 2024 1 hour ago, Emporium said: Just curious, is the UK category one of the first categories in your providers natural lineup ? Reason I ask, is that I have one friend who swear that his box, every time he turns it on, it goes to the 4th channel (yes channel #4 without any renumbering active)) in the first category (which in his case is a 24/7 channel). Funny part, I use the same service and it has happened to me 2 or 3 times (same channel), but originally I ignored it, as a fluke, that maybe I had accidently hit some button before powering down.   It's channel 8. Quote
allinghj Posted June 23, 2024 Author Posted June 23, 2024 27 minutes ago, pugsycan said: I am using the BT-400 remote And on one of my units when I turn off the tv it transmits a 8 the the stb (same frequency as the off signal as the tv's off) Just saying may be it I hit last channel and it takes me back to my regular channel  You nailed it. When I turn off the TV using the TV remote, it changes my stb to channel 8. Well done pugsycan! Quote
Emporium Posted June 23, 2024 Posted June 23, 2024 (edited) Lol.. Same codes as some of the 2nd tier brands like TCL, Haier, Vizio, etc..  My mom's does the same when she turns on/off her electric fireplace, she has a Haier Since the remote is connected to the STB using BT, you can try covering the IR receiver on the front of the STB. However there are some cases I've seen, that power on for the STB requires IR. But you can experiment.  Edited June 23, 2024 by Emporium 1 Quote
Ryu Posted June 23, 2024 Posted June 23, 2024 2 hours ago, allinghj said: You nailed it. When I turn off the TV using the TV remote, it changes my stb to channel 8. Well done pugsycan! maybe try to program again with tv with different code might help. 1 Quote
Emporium Posted June 23, 2024 Posted June 23, 2024 42 minutes ago, Ryu said: maybe try to program again with tv with different code might help. He said he had a Classic, so typically the Classic comes with a BT-250, so there is no programming as with the BT300/400. IT is just learning keys from TV remote. 2 Quote
