UnleashStreaming Posted April 19, 2024 Posted April 19, 2024 Having issues with seeing the playlist option for live tv. The initial channel works fine and so does VOD. Any troubleshooting ideas? Already tried multiple hdmi wire and screen resolution options. Quote
UnleashStreaming Posted April 19, 2024 Author Posted April 19, 2024 No, the different country category. Everything works fine but when I try to click the categories for live tv the screen messes up. I have attached a picture of it. Quote
Ryu Posted April 19, 2024 Posted April 19, 2024 did you try reboot? also try to switch media player and see if that helps. i had little similar to one time but when I switch media player did help me but then I switched back and was not able to reproduce. not sure what was it but you can try and let us know. Quote
Emporium Posted April 19, 2024 Posted April 19, 2024 Can you specify what box and what version of BuzzTV 5 you are running ? When you press Menu button, it should be on the bottom left in the menu. 5.0.xxx It has happened to me a while back and my experience was similar to Ryu. Quote
