Teksrvs Posted February 21, 2024 Posted February 21, 2024 Unable to get into the settings to go and flash out the cache or data. Just in a loop. I have blue and green lights on the E2 box. Quote
nbs. Posted February 21, 2024 Posted February 21, 2024 (edited) Same procedure Edited February 21, 2024 by nbs. 2 Quote
Teksrvs Posted February 21, 2024 Author Posted February 21, 2024 3 hours ago, dishuser said: loop? do you mean buzztv logo? No it’s not the buzz logo. Just a blue screen with google framework shut down over and over.. Quote
Emporium Posted February 21, 2024 Posted February 21, 2024 6 minutes ago, Teksrvs said: No it’s not the buzz logo. Just a blue screen with google framework shut down over and over.. Something obviously looped. Do a hard reset (link posted above by nbs). Quote
Ryu Posted February 21, 2024 Posted February 21, 2024 if hard reset does not work then you give a try to this might work. Quote
dishuser Posted February 21, 2024 Posted February 21, 2024 4 minutes ago, Ryu said: if hard reset does not work then you give a try to this might work. that's pretty old 1 Quote
