smokens Posted October 14, 2023 Share Posted October 14, 2023 Not sure why but my 4500 works well and still does , the only difference is when i power down the unit the green light stays on . It does not turn red anymore . It does power down and is on stanby ,but the light does not turn red anymore . I tried a few things but to no avail. any help appricited , thanks . Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 14, 2023 Share Posted October 14, 2023 I thought green was for ethernet? Quote Link to comment Share on other sites More sharing options...
smokens Posted October 14, 2023 Author Share Posted October 14, 2023 im talking about the light on the front of the box ,and im using wifi Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 14, 2023 Share Posted October 14, 2023 mine is blue or red for on off green is for internet Quote Link to comment Share on other sites More sharing options...
Ryu Posted October 15, 2023 Share Posted October 15, 2023 post your cec settings info Quote Link to comment Share on other sites More sharing options...
smokens Posted October 15, 2023 Author Share Posted October 15, 2023 Sorry i mean the blue light stays on . CEC are , cec switch ;off ,one key play ; off, device auto power off ; on , auto change language ; off. 1 Quote Link to comment Share on other sites More sharing options...
Ryu Posted October 15, 2023 Share Posted October 15, 2023 try turn ON cec settings and see if thats helps. Quote Link to comment Share on other sites More sharing options...
dishuser Posted October 15, 2023 Share Posted October 15, 2023 57 minutes ago, smokens said: Sorry i mean the blue light stays on . CEC are , cec switch ;off ,one key play ; off, device auto power off ; on , auto change language ; off. mine stays blue if I use suspend Quote Link to comment Share on other sites More sharing options...
smokens Posted October 15, 2023 Author Share Posted October 15, 2023 I tried a few things with cec but nothing seems to work . i figured out that if i am hard wired with it the light work properly but if i use wify the light does not go red when i turn unit off . ?? Quote Link to comment Share on other sites More sharing options...
