What2be Posted July 10, 2023 Posted July 10, 2023 Does the Logitech Harmony (hub based remote) support the buzztv classic? i cant seem to find it in the harmony database. I read in another sub forum (XR4500) that buzztv is listed in the harmony database. What is it listed under? Thanks Quote
Ryu Posted July 10, 2023 Posted July 10, 2023 (edited) https://support.myharmony.com/en-us/compatibility in search bar manufacture type buzztv and model type xrs4500 Edited July 10, 2023 by Ryu Quote
stdly Posted July 10, 2023 Posted July 10, 2023 I use a Logitech Harmony Companion (hub) with my BuzzTV XR4500 it works well. I only use the original remote for the home button. Quote
nbs. Posted July 10, 2023 Posted July 10, 2023 Classic remote is from a different company,allaboutbuzz should advise 1 Quote
Emporium Posted July 10, 2023 Posted July 10, 2023 5 minutes ago, nbs. said: Classic remote is from a different company,allaboutbuzz should advise True, but the basic IR codes are the same, no ? My IR200 still works fine on an X5 and the Classic and vice versa, in IR mode. OK, it it is BT paired mode, that is a different story. Quote
