PPett Posted August 13, 2021 Share Posted August 13, 2021 I am unable to record programs and play them back. The only way it works is if I record While the program is currently running and leave it on thst channel there must be a way to program recordings and actually have them able to play back. please advise 1 Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 13, 2021 Share Posted August 13, 2021 you cant record and change channels 1 Quote Link to comment Share on other sites More sharing options...
PPett Posted August 19, 2021 Author Share Posted August 19, 2021 No! I have purchased a 1TB hard drive to support the storage space for all recordings. I record the program onto it and it still does not allow play back. It only sometimes works when I record and leave the channel on the actual recording program is there something wrong with my box,? Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 19, 2021 Share Posted August 19, 2021 You can't record and change channels. Quote Link to comment Share on other sites More sharing options...
Ryu Posted August 19, 2021 Share Posted August 19, 2021 as nbs said you have to stay on that channel until it stops recording. if you start recording and change channel then recording will stop. whatever you have recorded already if you want to play that then go to all apps, open up vlc player and all of your recording should be there. click on them and play back your recordings. Quote Link to comment Share on other sites More sharing options...
dishuser Posted August 19, 2021 Share Posted August 19, 2021 or just press pvr button on remote Quote Link to comment Share on other sites More sharing options...
Maestro701 Posted August 22, 2021 Share Posted August 22, 2021 On 8/13/2021 at 2:40 PM, PPett said: I am unable to record programs and play them back. The only way it works is if I record While the program is currently running and leave it on thst channel there must be a way to program recordings and actually have them able to play back. please advise There is a way...... Upgrade to the 4900 buzz unit and get a service that supports record one channel while you watch another. Good luck! Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 23, 2021 Share Posted August 23, 2021 1 hour ago, Maestro701 said: There is a way...... Upgrade to the 4900 buzz unit and get a service that supports record one channel while you watch another. Good luck! he doesnt need to upgrade .he just needs to wait 1 Quote Link to comment Share on other sites More sharing options...
Maestro701 Posted August 24, 2021 Share Posted August 24, 2021 On 8/22/2021 at 9:05 PM, nbs. said: he doesnt need to upgrade .he just needs to wait When the wait is over I can imagine the huge sigh of relief from users Quote Link to comment Share on other sites More sharing options...
PPett Posted August 24, 2021 Author Share Posted August 24, 2021 On 8/22/2021 at 7:34 PM, Maestro701 said: There is a way...... Upgrade to the 4900 buzz unit and get a service that supports record one channel while you watch another. Good luck! Thank you! 1 Quote Link to comment Share on other sites More sharing options...
Andy Posted September 18, 2021 Share Posted September 18, 2021 On 8/24/2021 at 6:11 AM, Maestro701 said: When the wait is over I can imagine the huge sigh of relief from users Wait for what? Mine will only record anywhere between 2 and 10 minutes worth of the program. Doesn't matter if I use internal or external, and I have tons of storage space. I am using the native "play" feature in the PVR menu. Other posts here suggest using an external player such as VLC. Doesn't the built-in native player work? Appreciate any advice. TY Update: I just discovered a setting in Advanced Settings/HDMI CEC for Auto Power OFF. I suspect that when the TV is turned off while waiting for a recording to start, the box detects this thru the HDMI interface and will shut itself off. I disabled Auto Power OFF...lets see what happens.... 1 Quote Link to comment Share on other sites More sharing options...
nbs. Posted September 18, 2021 Share Posted September 18, 2021 1 hour ago, Andy said: Wait for what? Mine will only record anywhere between 2 and 10 minutes worth of the program. Doesn't matter if I use internal or external, and I have tons of storage space. I am using the native "play" feature in the PVR menu. Other posts here suggest using an external player such as VLC. Doesn't the built-in native player work? Appreciate any advice. TY Update: I just discovered a setting in Advanced Settings/HDMI CEC for Auto Power OFF. I suspect that when the TV is turned off while waiting for a recording to start, the box detects this thru the HDMI interface and will shut itself off. I disabled Auto Power OFF...lets see what happens.... No one asked you to wait They were talking about another issue 1 Quote Link to comment Share on other sites More sharing options...
Maestro701 Posted September 18, 2021 Share Posted September 18, 2021 Sorry Andy, I was speaking to the other Andy. Quote Link to comment Share on other sites More sharing options...
Andy Posted September 19, 2021 Share Posted September 19, 2021 My setting didnt help. Quote Link to comment Share on other sites More sharing options...
nbs. Posted September 19, 2021 Share Posted September 19, 2021 I'd like to confirm that you are leaving box on when you record and also not changing channel 1 Quote Link to comment Share on other sites More sharing options...
