Features eg Miracast and casting
Scuba1900
On 5/29/2021 at 10:46 PM, Ryu said:
builtin miracast does not work but third party apps works fine. I tried one ApowerMirror app and worked fine.
The issue with the version of Miracast app is its very old
And with the newer phones + android versions that have come out over the years, am sure the protocols + apis etc are outdated
I think we will consider removing Miracast in our next update, to avoid complaints and bad customer experience.
  • Thanks 2
I agree with you. Thanks 🙂
Or just place here in the forum to upgrade to the latest Miracast ?
Can you share which Miracast software was installed ? Can this be upgraded from the play store ?
It was provided by Amlogic
So its a system app
So they do not update it on the PlayStore.
There are tons of other Miracast apps on the Playstore
So am not sure which one to recommend
