Racer Posted April 22, 2021 Share Posted April 22, 2021 Hi my new XRS4900 is over heating and stops working. no heat source near or around the box. Please help me . Thank you Stephane Quote Link to comment Share on other sites More sharing options...
nbs. Posted April 22, 2021 Share Posted April 22, 2021 I have had mine on pretty well 24/7 for the last three months with no issues Its only warm to touch 1 Quote Link to comment Share on other sites More sharing options...
DRAG00N519 Posted April 22, 2021 Share Posted April 22, 2021 I have mine on all day long with no issue at all Quote Link to comment Share on other sites More sharing options...
dishuser Posted April 22, 2021 Share Posted April 22, 2021 do you have a drive installed? Quote Link to comment Share on other sites More sharing options...
Racer Posted April 22, 2021 Author Share Posted April 22, 2021 No i don’t Quote Link to comment Share on other sites More sharing options...
Racer Posted April 22, 2021 Author Share Posted April 22, 2021 57 minutes ago, nbs. said: I have had mine on pretty well 24/7 for the last three months with no issues Its only warm to touch Thank you for the info Quote Link to comment Share on other sites More sharing options...
Racer Posted April 22, 2021 Author Share Posted April 22, 2021 36 minutes ago, dishuser said: do you have a drive installed? No i don’t Quote Link to comment Share on other sites More sharing options...
Racer Posted April 22, 2021 Author Share Posted April 22, 2021 45 minutes ago, DRAG00N519 said: I have mine on all day long with no issue at all Thank you for the info Quote Link to comment Share on other sites More sharing options...
Ryu Posted April 22, 2021 Share Posted April 22, 2021 take a outlet tester and test to make sure your outlet is correct. its not hot/nutral/reverse. Quote Link to comment Share on other sites More sharing options...
dishuser Posted April 22, 2021 Share Posted April 22, 2021 31 minutes ago, Ryu said: take a outlet tester and test to make sure your outlet is correct. its not hot/nutral/reverse. or just flip adapter around to see if issue goes away Quote Link to comment Share on other sites More sharing options...
Racer Posted April 22, 2021 Author Share Posted April 22, 2021 35 minutes ago, dishuser said: or just flip adapter around to see if issue goes away Will try. thank you Quote Link to comment Share on other sites More sharing options...
Racer Posted April 22, 2021 Author Share Posted April 22, 2021 1 hour ago, Ryu said: take a outlet tester and test to make sure your outlet is correct. its not hot/nutral/reverse. I will get a tester and Check Quote Link to comment Share on other sites More sharing options...
